Grinding from front wheel area at 20kph & above - Ford Truck Enthusiasts Forums
Old 05-22-2012, 03:13 PM
paxmann paxmann is offline
paxmann is starting off with a positive reputation.
Any help would be greatly appreciated. I am getting a grinding sound from the left front wheel while driving straight.. The sound stays the same when brakes are applied and does not change when selecting 4wd or 2wd.. I pulled the wheel off and had a look, but saw nothing unusual.. Any thoughts on steps to diagnose/repair the issue?
04 F-150 5.4 4x4
Old 05-22-2012, 03:21 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
Old 05-22-2012, 05:16 PM
Thanks, that thread was great! I will post once problem solved..
Old 05-24-2012, 02:37 PM
Update
After reading the thread everything you need to know about IWE's here is what I have found out; after disconnecting the line from the intake at the check valve sound is still present whether in 4low,high or 2wd it gets a little quieter when turning right. I found that the vac line coming from the left IWE is broken.. I will get on replacing that as soon as I can.. my concern now is since disconnecting the vacuum from the intake to the check valve made no difference I was hoping to make it drivable until I could replace the vac line.. anyway since it made no difference does this likely mean there are more issues other than the broken vac line... I am moving next week so I desperately need to make this truck drivable.. Help!!
Old 05-25-2012, 06:22 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
Might be a wheel bearing gone bad.
Old 05-25-2012, 11:50 AM
bearing
Maybe I do have 2 separate issues, bearing and vacuum line.. Is it difficult to change the bearing? or does it come as a bolt on hub assy?
Old 05-26-2012, 11:08 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
I may be wrong, but I was under the impression that the front hubs need vacuum to keep them from engaging. Disconnecting would not help. The leak needs to be fixed.
Front end grind Jitterbug 1987 - 1996 F150 & Larger F-Series Trucks 5 01-31-2010 09:11 PM
Grinding sound when in 2H Paul37 Expedition & Navigator 2 06-03-2008 07:59 PM
grinding when turning mattyzx3 Excursion - King of SUVs 2 09-27-2007 08:27 PM
92 Explorer still getting grinding/thumping noise in 4x4 69mustang Explorer, Sport Trac, Mountaineer & Aviator 4 03-05-2005 11:11 PM
1998 explorer grinding noise in 4wd wvmiller68 Clutch, Transmission, Differential, Axle & Transfer Case 0 01-24-2005 08:12 PM
Tags
2003, area, boiss, front, grinding, happening, making, motion, navigator, noise, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
