Self-adjusters
Old 05-22-2012, 10:29 AM
Y-oh-Y's Avatar
Y-oh-Y
Y-oh-Y is offline
Self-adjusters
I am looking to install self-adjusting brakes on my 60 f100, has anyone done this ? What years would fit ?, early 60's ? I have stock drums front and back. Thanks, Mark
Old 05-22-2012, 05:26 PM
blue57's Avatar
blue57
blue57 is offline
Check this out
Go to this URL for your answer.
https://www.ford-trucks.com/forums/6...um-brakes.html
Good luck.
Old 05-22-2012, 06:01 PM
Y-oh-Y's Avatar
Y-oh-Y
Y-oh-Y is offline
Thanks, I have been looking at why it wouldn't work for a couple of weeks now, ain't found a reason yet. Mark
Good luck.
Old 05-22-2012, 07:33 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
I did it by installing a later model rear axle. They are easy to come by and cheap. Lots of advantages.... gearing etc. Last night I replaced the wheel cylinders on my '92 axle in my '59. They were in stock at napa for $15.65 each, and that's for a one ton. Actually last night was the first time I ever dealt with a brake job with self adjusting brakes. Sort of clever how they work, but lots of fussy little parts....Still better than crawling under the truck and trying to remember which way to turn the spoon ......
Old 05-24-2012, 01:45 PM
blue57's Avatar
blue57
blue57 is offline
<TABLE style="BORDER-TOP-WIDTH: 0px" class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR title="Post 11865334" vAlign=top><TD class=alt1>....Still better than crawling under the truck and trying to remember which way to turn the spoon ...... </TD></TR><TR><TD class=thead colSpan=2></TD></TR></TBODY></TABLE>
Yeeeaaahhh buddy.
Old 05-28-2012, 06:39 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Self adjusters were not available for F100's until 1964. These self adjusters only work (if they work at all!) when you back up and step on the brake pedal.
The adjuster cable (there are 4, one inside each drum) is notorious for snapping. This may allow the cable guide to float around inside the drum.
What happens when this little charmer gets between the shoe and drum and you then step on the brake pedal?
The cable guide chews the hell oughtta both the shoe and drum. And, the adjustment wheels rust up, rendering the whole set up inoperable. NAPA once sold a kit to remove the pesky self adjusters.
Forgetaboutit! IMO, they're more trouble than they're worth.
MIKES 68 F100
248
05-22-2016 06:19 PM
JEFFFAFA
10-19-2013 01:10 PM
Snowking
07-29-2008 01:43 PM
JhnBrackett
Offroad & 4x4
02-24-2004 03:37 PM
Quick Reply: Self-adjusters
