59 3 Speed Snap Ring HELP!!!!!!!!!!
Old 05-22-2012, 04:14 PM
flamesoldier's Avatar
flamesoldier
flamesoldier is offline
ok here is a picture of the snap ring im trying to install on the inside lip of this 1959 3 speed output shaft bearing. I have tried everything to put it in including a piston ring compressor the ring is way to strong and it seems impossible to fit down in the inside diameter. Can some one point me in the right direction?
Old 05-22-2012, 04:39 PM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
I think that it goes in the groove in the outside radius of the that bearing.
Old 05-22-2012, 04:45 PM
flamesoldier
no....on the 59-60 f100's the ring goes into the front of the bearing and acts as a riding surface for the low/reverse gear to ride on....my question os how do i get that sucker in there cause after i popped it out of there its damn near impossible to get in but im sure there is a certain way to do it
Old 05-28-2012, 04:48 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Notice that the output shaft bearing has a groove in it. What would one assume fits into this groove since it isn't there just for looks?
8M-7030-A .. Output Shaft Bearing Snap Ring.
In front of the output shaft bearing is another snap ring: 8L-7064-A .. 1.224" I.D.
Here is the reason why taking pics before the trans is dis-assembled is important, especially if one has no shop manual or parts catalog.
Old 05-28-2012, 04:55 PM
flamesoldier
dummy...thanks for your input however getting down to where the snap ring went wasnt what you think...in the 1959-160 3 speed trans there is an extension tube the output shaft slides into the extension and seats up againt a stop then the snap ring in question goes into a grove on the inside of the extension housing to keep the bearing flush against the stopped part of the extension.
Old 05-28-2012, 05:47 PM
NumberDummy
These two snap rings were used from 1948 thru 1962 on all the Ford Light Duty non syncro first gear 3 speeds, installed in full sized Passenger Cars, F100's.
Old 05-28-2012, 05:55 PM
spurredon's Avatar
spurredon
spurredon is offline
Amen Brother!
Hang in there soldier! It will come together in time.
nsboyd1210
06-10-2018 02:27 PM
4x4 Bart
05-28-2009 05:26 PM
marty68
01-23-2008 02:45 PM
Ernieweaslefat
04-12-2007 07:33 PM
Black89F150
03-13-2005 08:03 PM
Quick Reply: 59 3 Speed Snap Ring HELP!!!!!!!!!!
