Diagnostic Scan Reading P1209 code! - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-22-2012, 08:42 AM
ford7.3l's Avatar
ford7.3l ford7.3l is offline
ford7.3l is starting off with a positive reputation.
I just bought an 01 f350 7.3L dually back in march. I got it for a pretty good price and changed out a couple of parts to get it running like new. But I have this one code we can't figure out, it reads p1209. Something having to do with oil pressure peak fault. My question to you guys is, what would it more likely to be a high pressure oil pump or an ipr sensor?
Hope to hear from you soon guys thanks!
Old 05-22-2012, 09:30 AM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
KE15 CONTINUOUS DIAGNOSTIC TROUBLE CODE (DTC) P1211, P1209
DTC P1209 and P1211 indicates that injection control pressure was above or below desired level under normal driving conditions.
Possible causes:
incorrect oil or viscosity
poor oil quality
gel fuel/no fuel
low fuel pressure
damaged IPR valve
high-pressure oil system leak
damaged high-pressure oil pump
damaged PCM
Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
Old 05-22-2012, 09:39 AM
ford7.3l's Avatar
Possible causes:
poor oil quality
gel fuel/no fuel
low fuel pressure
damaged IPR valve
damaged PCM
The oil is good I run Rotella 15-40 and change it every 3 thousand miles. My Fuel pressure is good too, it reads nearly 85psi at idle and about 60 -65 when I punch it. I have no oil leak on the high pressure oil pump. So does that leave to replace the IPR?
Old 05-22-2012, 09:55 AM
mueckster's Avatar
Quote:
If you have access to a scan tool, i.e. Auto Enginuity, I would monitor ICP pressure and ICP Duty Cycle % at various rpms and loads. This would give an indication as to whether the IPR may be sticking. A bad ICP sensor could also be giving a faulty reading. Check for oil in the ICP connector.
Old 05-22-2012, 09:59 AM
ford7.3l's Avatar
Oh yeah that as well, we also replaced the ICP sensor from the very start thinking that might be the fix. So that's all in tact with no oil on the connector.
Old 05-22-2012, 10:05 AM
mueckster's Avatar
Then, I would look into monitoring the parameters mentioned and look for pressure increases to match a rise in Duty Cycle.
Old 05-22-2012, 10:10 AM
ford7.3l's Avatar
I have to look into it. So what will determine if its my High Pressure Oil Pump or my IPR sensor?
Old 05-22-2012, 10:21 AM
mueckster's Avatar
Response time. If the DC % rises faster than the pressure increase, then the IPR is sticking. If your DC % peaks with inadequate pressure, then you have HPOP volume or HPO internal leak issues. How does the truck run overall? Is it still stock, or modded in any way?
Old 05-22-2012, 10:29 AM
ford7.3l's Avatar
Its basically stock to me. All I've done to it is a str8 pipe exhaust and a K&N air filter. She runs pretty good I must say considering the 327k on it. Only thing that concerns me is a light sputter it tends to do at times. Mostly on take offs. Tends to somewhat lag a bit then out of nowhere it'll speed up and run like a champ. But other than that she's good. I do melon hauling with it and I average gross weight about 40 to 41k and these are daily hauls.
Old 05-22-2012, 10:30 AM
jwhitetail jwhitetail is offline
jwhitetail is gaining momentum as a positive member of FTE.
Programed or chipped trucks will throw this code sometimes.
Old 05-22-2012, 10:35 AM
ford7.3l's Avatar
Quote:
I highly doubt this truck has been chipped or programmed. Well atleast I notice no signs of it drive wise or under the hood wise
Old 05-22-2012, 01:49 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Look on your pcm under the dash and see if a chip is plugged into the pcm, that is one way to tell if its chipped.
Old 07-26-2012, 06:17 PM
2000powerstrokeDL 2000powerstrokeDL is offline
2000powerstrokeDL is starting off with a positive reputation.
Would the ipr or icp sensor make the truck put out whit smoke at a low rpm?
Old 07-27-2012, 05:16 PM
RedNNBlue's Avatar
RedNNBlue RedNNBlue is offline
RedNNBlue is starting off with a positive reputation.
Interesting problem that I may be sharing. I have seen white smoke from my truck twice in about 3 years, so I doubt that has much to do with it, but it could have just been the onset.
I have noticed a lag in power and started watching the ICP reading on the Edge Insight digital guage. I haven't monitored the duty cycle % yet, but I'll start now. The truck is chipped with a DP Tuner and I notice the same behavior in other settings, but mostly in the stock setting.
The symptom is the truck is sluggish and has very little "get up and go" until after the engine has been running for about 7-10 minutes. I notice that when its just started up (worse in cold weather), my ICP pressure reading may climb to only around 1,300 or 1,400 PSI but when its warmed up it will climb to as high as around 2,800 PSI at full throttle.
After thinking HPOP problem, I checked under the hood and noticed some oil in the valley. So now I'm leaning toward HPOP leak. Does it sound like I'm thinking in the right direction?
Any help is greatly appreciated. Thanks
Finally! New X/C code springs in! golfmedik Excursion - King of SUVs 88 06-03-2016 08:02 PM
7.3 codes p1209 and p1212 dluchsin 1999 - 2003 7.3L Power Stroke Diesel 3 04-21-2014 03:04 PM
Viair Install Complete with Pics... golfmedik 6.7L Power Stroke Diesel 10 11-24-2013 12:00 PM
99 7.3 lost power won't start FishOnTheBrain 1999 - 2003 7.3L Power Stroke Diesel 13 02-01-2012 08:56 PM
2001 7.3L PSD Codes: P1209, P1282, P1211 H60Driver Excursion - King of SUVs 0 08-26-2010 04:10 PM
Tags
1209, 73, code, diesel, f150, ford, obd, p1209, power, stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
