Cetane Booster - Page 2 - Ford Truck Enthusiasts Forums
Cetane Booster
Old 05-22-2012, 03:05 PM
FONRDAY's Avatar
FONRDAY FONRDAY is offline
FONRDAY is starting off with a positive reputation.
I have torn down lots of motors and I see what optilube does. Its not made for new low sulfur Diesel fuel.
Old 05-22-2012, 03:16 PM
FONRDAY's Avatar
Quote:
Originally Posted by cford716 View Post
I have been on this site and others for 2 years and have never seen anything like that mentioned before. Where are you getting this information? Kind of like the HPFP threads, we wants FACTS!
I am interested to hear what you know, but I would like more information than a general statement like that.
Maybe Optilube is okay back east but in california the fuel is very low sulfur and it cuase problems with egr valves,pistons injectors.
Old 05-22-2012, 04:15 PM
swhhfrc swhhfrc is offline
swhhfrc is starting off with a positive reputation.
What kind of mileage benefit are you guys seeing with the cetane enhancers, any appreciable? If so are you buying generic fuel or sticking to brand name fuels?
Old 05-22-2012, 05:19 PM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
Quote:
Originally Posted by jack_pine View Post
I have the exact same question with the 22 vs the 23. Tried asking that once before but no joy.............
Lubriticity would be the same. But 23 you would be making like a winter fuel. Less performance.
Old 05-22-2012, 05:24 PM
Hdslider's Avatar
Quote:
1st I would say buy fuel at a place that moves a ton of fuel. Large truck stops.
As for mileage increase maybe a tad. Think of it as like adding premium gas to a gas burner. Cetane booster makes it burn better.
Old 05-22-2012, 05:31 PM
jack_pine's Avatar
jack_pine jack_pine is offline
jack_pine is starting off with a positive reputation.
I really don't keep track of mileage very much but it does seem like it has ticked up slightly (I think) I try to use BP. Have been successful expect on long trips. Put in a few Pilot stops on those trips.....................So yes, brand name...
Old 05-22-2012, 06:49 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion Tuxedo Scorpion is offline
Tuxedo Scorpion is gaining momentum as a positive member of FTE.
difference between pm22 and pm23 is 23 has anti gel properties for winter conditions. both add lubricitiy to the fuel. i add pm22a every other fill or so. not OCD about, like the other things i am. like water spots and bugs and installs and....
Old 05-22-2012, 07:29 PM
doublenot7 doublenot7 is offline
doublenot7 is gaining momentum as a positive member of FTE.doublenot7 is gaining momentum as a positive member of FTE.
I use Diesel Kleen faithfully every tank.
Old 05-22-2012, 07:54 PM
cford716 cford716 is offline
cford716 is gaining momentum as a positive member of FTE.
Quote:
Not to be a pain but since I useing this I am interested in more information. What are you seeing that it is doing to the engine?
Has anyone else heard of any issues like this?
Old 05-22-2012, 08:13 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
the fuel is the same across the country, its federally mandated!
Old 05-22-2012, 08:33 PM
screwy's Avatar
screwy screwy is offline
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
I use Ford's pm-22, not because I think it's better then anything else, I wouldn't know as I haven't looked into it... but because if I have a fuel related problem I can say I went the extra mile to maintain my fuel system, using their recommendations, and I doubt they'd ever try and blame the Ford additive for causing it, like they might try to do for another additive, nor would they try and blame it on poor lubricity, as that would essentially be admitting both their additive and maintenance recommendations are flawed.
Old 05-22-2012, 09:27 PM
olds403 olds403 is offline
olds403 is starting off with a positive reputation.
Ford PM-22 here. 4oz per fill up. Sticky stuff I might add.......
  #28
Old 05-22-2012, 10:07 PM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
Quote:
x2
ten characters
  #29
Old 05-22-2012, 10:58 PM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
Quote:
Originally Posted by SavageNFS View Post
x2
ten characters
Hey Andre, what's this Ten Characters B/S.......LMAO
  #30
Old 05-22-2012, 11:20 PM
SavageNFS's Avatar
not a WHITE truck
Some Hawkeye learned me real good
Thoughts on balancing beads BigSexy78 1973 - 1979 F-100 & Larger F-Series Trucks 16 12-29-2016 12:16 PM
Discussion on Anti-theft Hacking and Suggestions Davparks 2017 Super Duty 14 12-18-2016 11:17 AM
Diesel Fuel Additive? kcwolf200 2017 Super Duty 15 12-01-2016 08:33 AM
Lets See those Tires and Rims on the Trucks CamF250Truck 1999 to 2016 Super Duty 351 08-24-2014 11:30 AM
does your GLOCK jam? BuiltToughF250 General NON-Automotive Conversation 17 03-03-2003 04:43 PM
Tags
2011, 64, 67, boost, booster, cetane, diesel, egr, f350, ford, fuel, imploding, oklahoma, pump, run
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
