Cost of having the oil pan gasket redone? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 05-21-2012, 10:47 PM
2000EX7.3L 2000EX7.3L is offline
2000EX7.3L is gaining momentum as a positive member of FTE.
I have heard the stories of pulling the motor to do this, but I believe it needs it. I stepped on it coming home tonight and noticed that almost immediately after pulling into the driveway I had a few fresh drips so I looked underneath and saw fresh build up around the pan lining.
So who has had a shop do this and what have you guys paid. Thanks in advance.
Old 05-21-2012, 11:32 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
First off, make sure you don't have a top-side oil leak collecting in the engine valley, running down the backside of the engine making you think your pan is leaking.
Also check the dipstick tube flange.
Stewart
Old 05-21-2012, 11:42 PM
About a week ago i took apart the top of the motor and cleaned out the valley, and I used a flashlight tonight and it was still relatively dry. I will have to check the flange(thanks for the tip) but I really believe its the pan. The girls got 250K on her but runs like a dream.
Old 05-21-2012, 11:44 PM
Stewart_H's Avatar
I was just hoping it might be something other than that labor intensive, time consuming pan leak.
Stewart
Old 05-21-2012, 11:47 PM
Quote:
Stewart
So I have heard. I will do more checking, but it also comes down to do it myself, or pay someone while I stay clean?!?
Old 05-21-2012, 11:52 PM
Stewart_H's Avatar
Your engine has to come out and be turned upside down to allow the sealant to cure. There is no gasket.
If you can pull the engine and have an engine stand, you're good to go.
Stewart
Old 05-21-2012, 11:53 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Don't fix anything that ain't broke! Get under there at the quarter car wash and clean that area and above it, then look again after a hundred miles. If you really want to find it put some dye in your oil. If it is the pan (random pan leaks are rare), tighten the bolts on that side first (don't break any), and look again after another 100 miles. Lower (appearing) leaks usually originate higher up.
Old 05-21-2012, 11:58 PM
Stewart_H's Avatar
Quote:
More good, excellent advice before you start spending your hard earned cash.
Good idea, Brent!
Stewart
Old 05-22-2012, 12:12 AM
Good call! Any particular dye? And any concerns about blasting away with degreaser and high power wash on the 7.3? I really appreciate all the help.
Old 05-22-2012, 12:21 AM
jdhart73 jdhart73 is offline
jdhart73 is gaining momentum as a positive member of FTE.
Ive used tracer before in other vehicles... not sure how much would be sufficient for a 6.0.
Amazon.com: Tracer Products TP34000601 UV Fluorescent Leak Detection Dye - Set of 6: Automotive
Old 05-22-2012, 01:20 AM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
I also would try to tighten the bolts over time they come loose. I had an oil leak I thought was a rear main seal, it turned out to be the rear most oil pan bolts were about 1, 1/2 turns loose! I had the shop that did my injectors tell me that the oil pan was replaced recently hence no rust on it! I would first see if it is the pan bolts. Also the mechanic said usually he would charge about 600 - 800.00 for an oil pan job simply because the only way to do it is pull the engine. There is a video of a guy replacing his on youtube on a 99 F350 Oil Pan Replacement Ford F350 Powerstroke 7.3L Diesel - YouTube
Old 05-22-2012, 01:15 PM
Quote:
Power wash won't hurt it there, in fact I spray my v-10 with degreaser and power wash it once in a while avoiding sensitive areas but never have a problem. All my cop boots are sealed at the top also. I haven't used tracer dye for a long time.
Old 05-22-2012, 01:32 PM
BuiltFordTough!'s Avatar
BuiltFordTough! BuiltFordTough! is offline
BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.BuiltFordTough! has a great reputation on FTE.
Ill of my bolts were about a 1/4 turn loose I need to stop mine from rusting soon.
Old 01-18-2013, 04:00 PM
SuperDad's Avatar
SuperDad SuperDad is offline
SuperDad is starting off with a positive reputation.
There was a problem with the V10 oil pans. Ford now makes a replacement pan and gasket. It' $169.00 at the dealer. They say 8hrs labor to install.
2003 f150 4.6 triton to expedition 4.6 swap ecu help autox65 1997 - 2003 F150 8 03-08-2016 10:06 PM
1977 F250 4x4 Time for a new oil pan? mbeards 1973 - 1979 F-100 & Larger F-Series Trucks 13 10-07-2015 12:30 AM
To RTV or not to RTV. That is the question. JustinP 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-23-2015 02:29 AM
97 F 350 w/ 460 Oil Pan boxtruckgene 1987 - 1996 F150 & Larger F-Series Trucks 8 10-07-2012 12:56 PM
352 oil capacity baracade 1961 - 1966 F-100 & Larger F-Series Trucks 49 09-16-2012 07:44 PM
Tags
1997, 2003, 73, cost, escape, f250, ford, gasket, leak, oil, pan, redo, seal, shop, sti
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
