New Member just saying HI!
If your 56 has the beam front axle, the Toyota PS box is an ideal swap, your wife will love it and it's a lot less expensive than the R&P for the beam. A couple people have tried the R&P, it is still too new to draw any conclusions, but the constantly sliding steering shaft joint would concern me.
Haven't done a search here yet on it...never thought a a Toy and older Ford suspension would mate easily....I like easy swaps and Cheap
Thanks
Read about swapping in the Toyota PS box here. It fits and works like it was made for this application:
Toyota Steering Box Swap For 1948-1960 Trucks .: Articles
If you don't have one call Mid Fifty: Mid Fifty F-100 Parts - Home and ask the gals to send you one of their free catalogs. It is far more useful than as just a list of parts, you'll be referring to it regularly, and MF is an excellent source of parts and advice.
The swap is incredibly easy, G.R. I did it on my '56. The only thing that would complicate the process and cost extra $$$ would be if you were hard-nosed about having a tilt column-shift. Any other way (non-tilt or floor shift) is cheaper and easier, but I was hard-nosed about having a column shift tilt wheel. Also be sure to rebuild your drag link while you're at it. It's cheap and easy too.
Only other obstacle would be to scare up the proper bracketry and a pump to run it. Since you're running the same aquarium pump I am this should be easy for you. I used a p/s setup from a '68-'72 F100. You could also use a setup from a '73-'76 F100 aswell. The '68-'72s had a provision to mount a p/s oil cooler off of the bracket itself. The '73-'76s had extra switch-backs in the return line tucked inside of the driver's frame rail to serve as a cooler. Unless the truck had the HD cooling option. The pre-'67 FE trucks and cars would be usable too, but are gettin harder to find and are made up of more pieces. The '68-72 and '73-'76 are common as water and should be easy to locate. Just be sure to grab all associated spacers, pulleys, and whatnot.
Here's a pics of mine.
The Anglia was a former Gasser out of the mid-west back in the day that was undergoing a rebuild to a street rod by the previous owner before he had serious heart attack and decided to sell it. Straight axle was replaced with a Pete&Jakes modified M II suspension. The engine is a bit over cammed for street friendly use and it is definitely in love with gas stations. Under hard acceleration with line-lok it will pull the front end off the ground in a heartbeat...Thank God for wheelie bars! Not real comfortable to drive long distances...but it sure garners attention at shows and cruise nights.
I'd suggest replacing the stock tie rod with the HD one from Mid Fifty when using PS. The OEM flexes and bends a little too easily. I used a tilt column to make it more comfortable for me and my now ex-wife to adjust the driving position for long distance driving. The large stock wheel and "bus driver" driving position is foreign to anyone who has not driven early vehicles.
Pictured below: Stock tie rod on top, Mid-Fifty 'Improved' tie rod on bottom.
pabooth89
10-10-2017 03:10 PM
Marcee
21
07-13-2009 09:54 AM
TheMadFabber
28
12-08-2004 12:29 PM
