Any Advise
Any Advise
Finally getting around to starting up my 55 f100 Straight 6, I had her tore down to the engine block and repainted her while doing a mini over haul on her as I built her back up. All she needs is oil and antifreeze and she’ll be ready!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
I know I put her out of timing removing and installing the harmonic balancer. (Noob…) <o></o>
<o> </o>
I was hoping you guys could give me some advice before I try to turn the key on her. Things I need to do or look for before I start.<o></o>
<o> </o>
Thanks Guys.
[/IMG]
<o></o>
[/IMG]
<o> </o>
<o> </o>
<o> </o>
Thanks Guys.
[/IMG]
<o></o>
[/IMG]
Why would it have gotten out of time when you R&R'd the balancer? Timing is controlled by the timing chain and the distributor housing rotation. The balancer is keyed to the crank and can only be installed in one position. Unless you had the timing chain off and/or the distrubutor out, the timing should be good for start up.
gordo2
22
07-06-2011 11:47 AM
CALINLEIR
04-28-2009 01:47 PM
lil smokey
04-17-2007 07:58 PM
