Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 05-21-2012, 12:33 PM
Fireboater Fireboater is offline
Garage is empty, add now
Fireboater is starting off with a positive reputation.
6.2 Super Duty Power Upgrade
Hi there, is there any word on ford going to upgrade the power of the 6.2 yet i.e. 3 or 4 Valve heads.
Thanks
John
  #2 (permalink)
Old 05-21-2012, 08:25 PM
nico963 nico963 is offline
nico963 is gaining momentum as a positive member of FTE.nico963 is gaining momentum as a positive member of FTE.
Quote:
Thanks
John
I've been kinda waiting in the shadows for the same answer.
I'm still waiting...
__________________
Rob
2007 F-250 6.0 CC SB 4x4 Black Sport FX4
20in Black BMF Novakane 8 W/ Toyo M/T 33x12.50x20
Stock Motor
2004 F-250 6.0 CC SB 4x4 Black Sport FX4
Sold-She was problem free.
  #3 (permalink)
Old 05-22-2012, 07:27 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Subscribed ... 3-valve heads would do wonders... not sure how they'd get two spark plugs in there though
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. Ž
  #4 (permalink)
Old 05-22-2012, 07:36 AM
Byram's Avatar
Byram Byram is offline
Byram is gaining momentum as a positive member of FTE.Byram is gaining momentum as a positive member of FTE.
Subscribed...
maybe bore/stroke it out a little and add the 3 or 4 valve -
then make the trans like a 8 speed
I would then trade the 2011... & that pretty unusual for me - I usually drive 'em 8-10 yrs...
__________________
2011 F-250SC XLT
6.2; 3.73 EL; 4x4; BFG M/T 285's; B&W Turnover; Ranch Hand; Oasis XD 4000 OBA & Aux Battery; 5 Star assisted!
"Peace is that brief glorious moment in history when everybody stands around reloading".
  #5 (permalink)
Old 05-23-2012, 06:37 PM
Louisville Joe Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.
The whole point of the 6.2L 'Boss' was to make an engine with enough bore spacing to not only give at least a 4" cylinder bore, but it turn provide enough room for adequately sized valves in a 2 valve configuration. The 3 valve head on the Mod. was a 'band-aid'. The bore size was so small it limited the size of the intake valves. The quick solution was to use 2 small intake valves instead of one large valve, so shrouding was no longer an issue and the total intake 'window' was increased. That is why the 3 valve head worked so well on the Mod.. A 3 valve head would probably not be near as effective on a 6.2L because the single valve they currently use is quite large, and there is not a shrouding issue due to the lager bore. At this point it looks like the 'Boss' family will not be developed for high performance applications (that is what the 5.0L 'Coyote' is for). I think at some point a larger displacement 'Boss' (7.0L?) will replace the 6.8L V-10, but I don't think any 3 or 4 valve configurations are in the cards. I could be wrong. No clue as to why the 6.2L has not replaced the 6.8L V-10 in the F-450 and larger trucks yet.
  #6 (permalink)
Old 05-23-2012, 06:45 PM
Byram's Avatar
That is good to know... Not being much of a mechanic - I didn't realize the 2/3 valve issue..
I think that you are right - the v-10 in the larger rigs needs a higher displacement version of the 6.2 to replace it... I only hope that Ford will let us "upgrade" from the 6.2 in the 250/350 trucks....
__________________
2011 F-250SC XLT
  #7 (permalink)
Old 05-23-2012, 06:58 PM
It is possible that if a larger 'Boss' was made for the commercial trucks it might find its way into Super Duty pickups, but remember that HD pickups must now conform to fuel economy standards. It seems that all the manufacturers are building their large gasoline engines right around 6.2L displacement, and I think it is because that size gives the best balance between power and economy. My guess is future gains in horsepower and torque will come from direct gasoline fuel injection because it actually helps fuel economy in the process. GM will have D.I. on the Gen. V 6.2L next year, and I hear it makes well north of 400 h.p.. And I heard a rumor that the 6.2L 'Boss' was designed with D.I. in mind..........
  #8 (permalink)
Old 05-24-2012, 03:43 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Thumbs up
Quote:
YES...agreed. D.I. is the way of the future for the 'Boss' line. Which...IMHO...should have been configured that way from the start.
The only other thing to get the 6.2L 'Boss' with more hp/torque is to go ecoboost straight away. Add the D.I. and twin (small) turbo...with ecoboost thinking and strategy.
That would make it so much more efficient! Plus...adding that 8 spd Auto tranny...and we could be seeing a 15% to 20% increase in mpg's!..with the proper gears.
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
Tags
35, 62, duty, engine, exhaust, f250, ford, heavy, issues, performance, power, super, supercharger, superduty, truck, upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
