Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-21-2012, 10:48 AM
berry1234's Avatar
berry1234 berry1234 is offline
Garage is empty, add now
berry1234 is gaining momentum as a positive member of FTE.
100K Mile Spark Plugs(pics)
Here are my plugs with 100K miles on them from my 08. Removal was pretty much pain free except the rear driver side plug as it had hard vacuum hoses and wire looms directly over the COP-that one took 15 minutes. The other took about 5 minutes each. Here are the plugs.
Click the image to open in full size.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #2 (permalink)
Old 05-21-2012, 11:56 AM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
So are you just going to put them back in for another 100,000?
__________________
1997 F250HD 4wd, 460-5-speed Ext. Cab, Blue
2007 Navigator L Dark Blue Pearl
2003 Mercury Marauder, Dark Blue Pearl, Trilogy Supercharged, 13.1 @ 105
  #3 (permalink)
Old 05-21-2012, 02:58 PM
07xpyebel's Avatar
07xpyebel 07xpyebel is offline
07xpyebel is starting off with a positive reputation.
Berry,
Why did you wait so long to change?
  #4 (permalink)
Old 05-21-2012, 03:04 PM
berry1234's Avatar
Quote:
Originally Posted by 07xpyebel View Post
Berry,
Well the manual suggest 90K and I just didn't have the money or time to do it any sooner. So 10K over wasn't too bad. All other maintenance is done on time.
__________________
  #5 (permalink)
Old 05-21-2012, 06:16 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Berry, did you follow any specific procedure for removing them ? Mine's an 08 also, built after the Nov 07 cutoff date for the new plugs so I was just wondering if you did anything special.
Thanks,
Matt
  #6 (permalink)
Old 05-21-2012, 06:26 PM
berry1234's Avatar
No. If you have the brown boots you are safe. Didn't take much effort. I cracked the first one 1/4 turn, sprayed PB Blaster and let it set for 20 minutes. I tried not using it on the second plug and it was virtually the same, easy so I didn't do it on the rest of them.
If you have the black boots, it's a different story.
__________________
  #7 (permalink)
Old 05-21-2012, 06:32 PM
blueovelboy's Avatar
blueovelboy blueovelboy is offline
2012 Ford F-150
blueovelboy is gaining momentum as a positive member of FTE.blueovelboy is gaining momentum as a positive member of FTE.
my 07 has black boots and i hate the fact that i need to change them! i am at 84,000 and have toyed with letting the dealer do them for $300 plus plugs well thats what i was told it cost if no trouble rises
__________________
2012 F150 XLT 4X4 crew cab 5.0 with 3:55 lockable rear end
  #8 (permalink)
Old 05-23-2012, 06:15 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Can you put old and new side by side? Gotta admit I've never seen these plugs out of the engine. Mine were changed by the dealer in the past month or so at 100,000 miles.
-- Chuck
  #9 (permalink)
Old 05-24-2012, 08:57 AM
07xpyebel's Avatar
Berry,
Have you notice any changes? better fuel economy, smoother idle etc.
Thanks
  #10 (permalink)
Old 05-24-2012, 10:35 AM
2012 Ford F-150
after reading this i went and had mine changed for a total of $425. dealer told me they had three that broke and need to do a retraction on one the other to broke but came out still. today is my first day with it back well the wife has it ill post up how it running when she gets back!
__________________
  #11 (permalink)
Old 05-24-2012, 11:19 AM
ecyrbh ecyrbh is offline
ecyrbh is starting off with a positive reputation.
Can someone inform me on what the issue is with changing the plugs...I know they are pain to get to,but what is the issue with the brown and black boots...I've never heard of this,so I just want to be prepared....Thanks
  #12 (permalink)
Old 05-24-2012, 11:51 AM
berry1234's Avatar
Berry,
Thanks
It runs better. Throttle response seems a little snappier and idles a bit better. The old plugs were not in bad shape so there is not a lot of difference compared to someone who's plugs are worse off.
I don' have a new one to show the difference, but other than color and a very minor amount of wear, they look the same.
If you have brown COP boots you are safe-the plugs and heads have been update to eliminate the broken plug issue. The dealer still quoted me $299 labor for my plugs. It took me a total of about 1.5 hours-but I don't work fast and took my time. It's really not hard at all. Much easier access than most cars.
If you have the black boots on your 2008 or 2007 chances are you will break a plug.
You need a 9/16th spark plug socket-I couldn't find one locally and used a 14mm in a pinch. I would suggest getting a 9/16th magnetic socket. Other wise you need a telescoping magnet to get the plug out after it's loosened-it's too deep to reach with your fingers.
__________________
  #13 (permalink)
Old 05-24-2012, 12:07 PM
Great...I have an 08 with 48k on it...I know its a little too soon to replace plugs and mine runs perfect,but will I possibly benefit from doing it earlier and what is the production dates or series that I can use to determine if I may or may not have a problem without having to look at the boots???...What plugs are being recommended to avoid future issues???....Do these engines also have the plug blowout problems that the earlier ones did???..
  #14 (permalink)
Old 05-24-2012, 06:00 PM
2012 Ford F-150
just got to drive mine to the store and back and what a difference it seems to have made it as smooth as a baby's bottom!
__________________
  #15 (permalink)
Old 05-24-2012, 06:13 PM
berry1234's Avatar
Quote:
Well can you pop the hood and look at the boots? It takes about 10 seconds. Brown=good, Black=bad.
__________________
Tags
100k, 2000, 2004, boot, f150, ford, instructions, lightning, location, miles, navigator, pics, plug, plugs, removal, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
