Head Gaskets and ARP Studs
Old 05-21-2012, 09:40 AM
polosabre's Avatar
polosabre
polosabre is offline
My 6.0 has finally let me down. It's a 2004 with 167000 miles on it. The oil temp was reaching 255 with nothing in tow. Coolant temp around 190-195. I took it to a shop and they are going to do ARP Studs, OEM head gaskets, HPOP, Oil Cooler, Fuel Injectors, Water Pump, send heads to machine shop to get checked, reflash computor with updated version, and belts and hoses. I already deleted EGR Cooler, added coolant filter, turbo cool down timer. Anything else I'm missing please let me know.
Old 05-21-2012, 10:29 AM
MauleOne's Avatar
MauleOne
MauleOne is offline
Studs
Sounds like you have it covered. Sorry your 6.0 let you down but when you get this work done it should last forever. They really are a good engine.
Are you having the turbo cleaned or replaced. They get sticky when they get a few miles on them.
Old 05-21-2012, 10:51 AM
bpounds's Avatar
bpounds
bpounds is offline
Do some research on those head gaskets. I've not heard of Diamond. But lots of experienced folks say to stick with OEM gaskets. Maybe you are thinking of Black Onyx? Many complaints about those.
AARP studs? I think I'm one of those!
Old 05-21-2012, 11:11 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
So you had a clogged oil cooler and they threw a pile of parts at it while it was down? Or were there symptoms of the heads actually being blown? Nothing wrong with modding up a 6.0, just wondering if it was voluntary or if you got sold on it being broke down when the only warning sign was oil temp.
They replaced the actual HPO pump itself? It's odd to replace the pump, but not mention the IPR valve at all. Did all 8 injectors take a crap at once or are you switching them out on a hunch? What's your fuel pressure at? Why the water pump replacement, was the impeller torn up?
Old 05-21-2012, 11:55 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.0L Powerstroke Diesel forum.
Old 05-21-2012, 08:37 PM
polosabre's Avatar
polosabre
I had already changed the oil cooler and an egr delete kit. I am the one wanting the head gaskets and studs. The mechanic just suggested the hpop and ipr valve (forgot to include) He also suggested the fuel injectors since I was spending money to prevent problems down the road. He has suggested the additional parts but in no way did he say I had to have them.
Old 05-21-2012, 10:13 PM
Fulthrotl's Avatar
Fulthrotl
Fulthrotl is offline
before i found the online forums, what i heard from everyone was this:
OEM head gaskets. don't go near anything else.
the shop who did my engine had a BO motor in for new head gaskets,
after 9 months, when i dropped mine off for rebuild.
Old 05-22-2012, 09:26 AM
spocky1187's Avatar
spocky1187
spocky1187 is offline
From all the reading I've done here it seems that everyone sticks with OEM HG, so when mine came time I too stuck with OEM
Old 05-22-2012, 12:05 PM
JIM_C's Avatar
JIM_C
JIM_C is offline
I was gonna say - AARP studs? That sounds like a bad truck stop magazine! lmao
Old 05-22-2012, 12:27 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
So oil temp is 255 with new oil cooler? Or am I reading wrong?
Old 05-22-2012, 01:39 PM
BPofMD's Avatar
BPofMD
BPofMD is online now
Received 1,097 Likes on 997 Posts
Rusty - you read wrong. He said "The oil temp was reaching 255 with nothing in tow. Coolant temp around 190-195. I took it to a shop and they are going to do AARP Studs etc." Don't think he posted the AFTER temps.
Old 05-22-2012, 01:44 PM
Rusty Axlerod
............ I already deleted EGR Cooler, added coolant filter, turbo cool down timer, and oil cooler. Anything else I'm missing please let me know.
That's what made me ask^^^^
Old 05-22-2012, 01:47 PM
Rusty Axlerod
I had already changed the oil cooler and an egr delete kit........
Again, sounds like it was done previously.
Old 05-22-2012, 01:54 PM
BPofMD's Avatar
BPofMD
Ummm, maybe I should learn to read!
Old 05-22-2012, 01:56 PM
BPofMD's Avatar
BPofMD
Maybe he replaced the oil cooledr way back in mileage like I had to do, near 50k and now he's doing it again?
Quick Reply: Head Gaskets and ARP Studs
