HEATED trans flush in Detroit/Downriver area? - Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: Toyman
Old 05-21-2012, 10:18 AM
RickBraden RickBraden is offline
RickBraden is starting off with a positive reputation.
Read a bunch from Ford Diesel Techs saying a heated trans flush is the only way to go since my trans has a 170* t'stat in it. Called 3 Ford Dealerships & you'd think I was asking for an "Outer Space tune-up.". Does anyone have any suggestions for me. Trying to take good care of this fine running machine. Thank you.
Old 06-04-2012, 08:49 AM
craftsmangary's Avatar
craftsmangary craftsmangary is offline
craftsmangary is starting off with a positive reputation.
I've never seen a "heated" trans flush machine. I did a google search and didn't find anything, so IDK. I bought a T-Tec 500 back a few years ago and it was one of the beast out there at the time. I have used it on transmissions with the by pass, to use it you have to get the trans up to temp so the fluid is going through the cooler, you will get 6-10 quarts flushed before it cools down and stops flowing, then you need to get it back up to temp and finish the flush. IDK of any other way to do it.
Old 06-04-2012, 03:44 PM
Thanks for info. They must have one because others have mentioned it. I sure would like to be able to have mine flushed that way.
Old 06-04-2012, 05:22 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
For me I prefer drain whole and new filter instead flush.
Most flush cases I heard ruin transmission later.
Old 06-14-2012, 12:09 AM
Well did anybody find a heated transmission flush machine? I have done a couple Goodle searches and couldn't find one. None of the top flush machine manufactures make one. So IDK??
Heated Transmission Fluid Flush CollinsCD Maryland Chapter 9 08-06-2014 07:18 AM
Heated Transmisson Fluid Change CollinsCD Delaware Chapter 0 07-30-2014 01:02 PM
Caigs List Find just another truck 1999 - 2003 7.3L Power Stroke Diesel 4 02-24-2011 04:07 PM
5R55S Noise Matt In Detroit Clutch, Transmission, Differential, Axle & Transfer Case 6 02-17-2009 04:15 AM
Red antifreeze that meets Ford spec? wgw 1999 - 2003 7.3L Power Stroke Diesel 6 06-19-2002 01:31 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
flush, heated, machine, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
