1995 Ford f150 will not turn off.
Hello, I have a 1995 ford f150, it will start fine, however it will not turn off when I turn the key.Is their another way to shut it down other then taking the plug off from the alternator and removing the wires from the battery?.More so something that could be done inside the truck?.I will taking it apart further when I have some time, but currently I just want a quick fix if there is one :/.
Ignition actuator....here is some info: Steering column teardown and ignition actuator replacement in a 1995 (92+ Columns) - FSB Forums
Curated Content Editor
General Automotive Discussion
06-19-2017 03:13 PM
imsorope
08-25-2014 09:31 PM
