You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
You would need to install a correctly functioning PCV system in its' place.I recommend visiting the Y-Block Forum on FTE for advice on how to properly install one.
That leak,while annoying and frowned upon in todays' more environmentally-conscious world,is normal - sort of.The intent was to vent crankcase fumes,while going down the road at relatively higher speeds.The reality,though, is different than intended. "Marking your territory" is part of the Y-Block experience.Embrace it.
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
Like the man said she is just marking her territory. Y-Blocks, Harleys. Flat heads among others. Of them it's been said if she isn't leaking oil she don't run.
__________________
85 XLT Bronco 351W HO 4V Dual Pipes 33X12.5 BFG's 62 Uni 390 C6 Custom Cab Not Yet Sold
Looking to buy a 48/50 F Anything If ya have one contact me. Don't just Modify it Fordify it
its the tube on the lower left hand side of the block. it leaks despite cleaning the canister and changing the screen.
Did you replace its gasket? Are you even aware there is one? Prolly not after I've read what you've said. If there's no gasket, you're gonna have an oil leak.
As the engine runs it get vapors in the crank case that if not vented in some way can be corrosive to the internals. The vent tube is designed that when you drive the air blowing over the end of the tube creates a vacuum on the crankcase. It pulls fresh air in through the oil fill cap and "exhausts" the vapors out the tube. When you shut down the engine the vapors cool, then condense and drip. If you have a worn engine with lots of blow by, this get worse.
A PCV valve used the engine vacuum to suck on the crankcase, the oil fill cover is still the inlet and the vapors get burnt and exhausted out the tailpipe. No more drips. The system is fairly simple but you need a good vacuum source.
I replaced mine with a PCV valve. I removed the tube assembly, cut the tube off, made a rubber grommet that would accept a PCV valve and I had a good vacuum source from my new Edlebrock carb. I also replaced the oil fill cap with a new one with a nice clean filter. Works fine, I will try to take a few pics tonight after work for you.
At one time there was an aftermarket conversion kit, I have seen them on eBay, but it is easy either way.
Thanks for the info. i would appreciate some photos if you can and i'll also look on ebay and see if i can find anyhting. good looking truck in your photo.
PICS:
Vacuum source on the carb. Oil Fill Cap (vented), PCV Valve where tube used to come out.
thanks for the photos. I have a vented oil filler cap already. so it looks like you put a pcv valve inline from the old attachment point on the block with a vacuum hose attached going to the carb, is that correct?
Yep, that is it. Where I removed the vent tube from the part that attaches to the valley pan, I put a rubber plug with a hole in it that the pcv valve sticks into. Then I blolted it back on the valley pan.
