shuts off - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
shuts off
Old 05-20-2012, 06:05 PM
Jskinner125 Jskinner125 is offline
Jskinner125 is starting off with a positive reputation.
shuts off
I have 2002 with the 7.3 PSD, i fueled up thursday at the same place I always do. Friday afternoon I was leaving a parking lot when i went around the corner the truck just shut off. I tried restarting it several times but no luck. after about 45 mins. it started right up and idled good. Got about 1-1/2 miles down the road and it did the same thing. i towed it home and replaced the cps and drove it around a couple of miles. as soon as i pulled up to my house it shut off again. and would not start. It is not showing any codes. if i let it sit for a while it will start back up again. HELP PLEASE!!!!!
Old 05-21-2012, 09:01 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 05-24-2012, 08:47 AM
just another truck's Avatar
just another truck just another truck is offline
just another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputation
Quote:
I would try the CPS, again..
Old 05-24-2012, 09:17 AM
Brother Les's Avatar
Brother Les Brother Les is offline
Brother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to beholdBrother Les is a splendid one to behold
What did you use to check the codes? a standard OBDII will not work on these trucks.
Is it raining or very wet when this happened?
Old 05-24-2012, 03:57 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
Disconnect the ICP sensor and see if it does the same thing.
As Les pointed out, you need to pull codes with something other than a generic OBD II reader. AE with Ford Package works.
If it still does it with the ICP sensor unplugged, I would look towards an IPR. I would pay to have codes pulled first though. An IPR is about $200
Old 05-24-2012, 08:29 PM
Jmatthews's Avatar
Jmatthews Jmatthews is online now
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
Was the cps you tried a new one?
Old 05-24-2012, 08:59 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
zx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant future
More important, is the replacement CPS a ford or IH one or one of the POC that parts stores sell?
Old 05-25-2012, 01:02 AM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Also check the wires on the IPR. Sometime they ware thur and short out. It cuts the HPO out and won't run the injectors. Just a thought.
Chet
Old 05-25-2012, 07:27 PM
shutts off
Hey guys just an update, it is a cps from a parts store, not from ford. It ran fine all week until Wednesday night I was driving it and it shut off again. It gives no warning just shuts off as if you turned the key off. When you try to restart it will not start, it acts like it's not getting fuel. If you let it sit for about 45 mins or so it will start right back up and idles perfect and runs good. I don't think it's a fuel problem b/c it never runs ruff or anything. it runs perfect until it shuts off. I drive 60 miles per day for work so that was around 200 miles or so that I drove before it cut off on Wednesday. I have it at a local shop right now but they can't seem to find the problem either. What is the "IRP"? I really appreciate ya'll taking the time to try and help me.
Old 05-25-2012, 08:01 PM
The IPR is the Injection Pressure Regulator. It is the regulator that controls the high pressure oil to the heads and injectors.
You may want to get a $20 CPS from Ford. They are less likely to have issues than the part store ones. You may also have a wire issue. Wires often chafe and can cause intermittent issues. Look closely at the harness connector at the valve cover area on the drivers side.
Tags
2001, 73, cuts, diesel, ford, safety, shut, sterling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
