Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1973 F-750 VIN Decode
Old 05-20-2012, 10:37 AM
Lad4811's Avatar
Lad4811
Lad4811 is offline
Hey everyone, just joined here today and I'm looking for some help decoding the history of my 1973 F-750 truck, The VIN is F75FVS15617.
WB 176
Color J
Model F756
Body DFB
Trans Q
Axle JQN
GVW LBS 27500
DSO 160983
Just wondering if anyone could help me with it, thought this would be the right place to ask! any help is appreciated, thanks in advance!
Old 05-25-2012, 07:37 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Lad4811
Hey everyone, just joined here today and I'm looking for some help decoding the history of my 1973 F-750 truck.
The VIN is F75FVS15617 / WB 176 / Color J / Model F756 / Body DF8 / Trans Q / Axle JQN / GVW LBS 27500 / DSO 160983
Welcome to FTE
Usually I decode this jazz within 24 hours after it's first posted, but just returned from a two week cruise-tour in Alaska.
F75 = F750 (gas).
F = 391 4V FT engine.
V = Kentucky Truck Assembly Plant.
S15617 = 1973.
176" Wheelbase.
J = Red.
F756 = F750 (gas), 27,500 lbs. GVWR
DF8: DF = Black all Vinyl // 8 = 81B Custom Cab.
Q = Spicer/Dana model 5652 5 speed Direct Manual Transmission.
JQN: JQ = Eaton model 17121 Rear Axle / 7.60-1 / 18,500 lb. capacity // N = Ford 9,000 lb. capacity Front Axle with Power Steering.
27,500 lbs. Gross Vehicle Weight Rating.
160983:
16 = Philadelphia PA Ford District Sales Office, where the original selling dealer ordered the truck from.
0983 = Domestic Special Order number, the truck was special ordered by the original purchaser, not "bought off the lot."
Old 05-25-2012, 08:27 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
WELCOME to FTE!
Old 06-05-2012, 11:17 AM
madrid london's Avatar
madrid london
madrid london is offline
vin decode 1973 C706
saw your reply and hoped youd decode my VIN C70EVS15579. thank you
Old 06-05-2012, 07:25 PM
NumberDummy
C70 = C700 Tilt Cab (gas).
E = 361 2V FT engine.
S15579 = 1973.
I noticed this in your other thread: MODEL code: C706 = C700 Tilt Cab (gas), 21,200 lbs. Gross Vehicle Weight Rating.
Old 06-06-2012, 07:37 AM
madrid london
Thank you, was curious as to wether the engine is original; odometer says 130,000 mi.
Old 06-06-2012, 07:38 AM
madrid london
thanks alot
Old 06-06-2012, 08:00 AM
NumberDummy
Do NOT believe the miles shown on the odometer, especially on a truck that was used commercially.
The odometers of these trucks read to 99,999.9 then return to ZERO.
So, it could have 130,000, 230,000, 330,000 miles or who knows?
Old 06-06-2012, 08:19 PM
madrid london
odometer flip
that's a bummer. things i look for to indicateage is wear on the pedals, and odometer digits comming up centered, the steering linkage is worn out , as is the rool-up door. the engine sure purrs. i tried getting info from US DOT, but came up empty so far
Old 06-07-2012, 07:33 AM
madrid london
got to thinking; and remebered a 1985 F250 diesel i had. the wear on the seat, and steering wheel slop. so i surmise this C706 has probably 230k miles if not more. engine seems tight, when i do a tune up i'll do a compression test
Old 08-04-2012, 06:13 PM
Lad4811's Avatar
Lad4811
Lad4811 is offline
Welcome to FTE
F75 = F750 (gas).
S15617 = 1973.
176" Wheelbase.
J = Red.
160983:
Thank you very much! I appreciate it!
EMH_metals
Large Truck
10-06-2020 03:35 PM
Gary38532
Large Truck
12-03-2017 08:43 PM
TaylorDiabetoSwifty
Large Truck
03-20-2017 12:51 PM
mpokoney
Large Truck
08-03-2015 12:08 PM
CPOly
04-27-2010 12:14 AM
Quick Reply: 1973 F-750 VIN Decode
