Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 05-19-2012, 10:21 PM
Cochip Cochip is offline
Garage is empty, add now
Cochip is starting off with a positive reputation.
My F100
So after some convincing I managed to wrangle away a very nice F100 from my nephew who wasn't doing anything with it. He tells me it's a 1960 and from some searching around I believe it has a 292 Y Block under the hood, other then that I'm not sure what's what. I would like some help deciphering the tag:
Serial #: F10C0H56244
WB: 118
Color: J
Model: F100
Date: 07G
Trans: B
Axel: 02
GVWR: 5000
146HP @ 3800RPM
Based on some research on this site I know most of this, except "date, color, trans, and axel"
Thanks ahead of time.
PS: I'm trying to put some pics on, but I don't have a photobucket account and they are too big to put into my gallery on here. An tips there too?
  #2 (permalink)
Old 05-19-2012, 10:44 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
Cochip Welcome to the orphanage!
Born on the 7th of july, Red, 3 speed over drive and 3.89 open diff.
Congratulations, whats your plans?
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #3 (permalink)
Old 05-19-2012, 10:57 PM
Right now I'm just trying to learn as much as I can about her. Honestly I'm not sure!! I kinda fell into this on a whim and was super surprised that the wife agreed to it!! It's going to be a slow process, I'm new to Fords, but first I just want to get the engine running. I believe I have some brake issues to attend to and the wiring looks scary! I'm actually hoping to find some help on where to start and how to go about resurrecting her. I was told she was a runner, but honestly I have no idea how long ago that was! Here are some outside pics. When I get her home I'll be able to post more and get them into my album.
So am I right in that the 1960 came with a 292? Originally I thought it was an 233, but another look under the hood changed that thought. Oh right the pics:
Click the image to open in full size.
  #4 (permalink)
Old 05-19-2012, 11:03 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Wow! Nice rustfree truck. Welcome aboard!
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #5 (permalink)
Old 05-19-2012, 11:06 PM
Quote:
Well the outside looks to be in pretty good shape, but I did notice a bit on the drivers side floor board near the door. I could see a bit of daylight through there!! :-) I did pull up the floor mat all the way to see the rest, but all in all it is not bad. I wish I could have crawled underneath to see a bit more but there are more then a few goat heads where she sits and I'm not that tough!!! Oh and thanks for the welcome!!! :-)
  #6 (permalink)
Old 05-19-2012, 11:08 PM
Cochip Yes your truck came with a 292! Your truck looks nice and straight.
__________________
1959 F250 4x4
Wally
  #7 (permalink)
Old 05-19-2012, 11:19 PM
Thank you. Any tips on the first steps to getting her running again. I'm not talking driving down the road, just starting her up? Figured I'd start there.
  #8 (permalink)
Old 05-19-2012, 11:28 PM
I would probably pull the plugs and oil the cylinders, put a carb kit in it as the carburetor is probably dried out and will leak like sieve! Then points and plugs. Fresh fluids and see what you got.
__________________
1959 F250 4x4
Wally
  #9 (permalink)
Old 05-19-2012, 11:39 PM
I wondered about putting some oil in the cylinders, but I wasn't sure how much. I would assume use the same weight as the engine oil, nothing special there right? I feel so nieve to this stuff right now. Never thought of the carb being dried out!! Hell I don't even know how to identify which carb it is. Also I'm going to have to source a new radiator as the original was left uncapped and is rust-city, not to mention what is living inside of it now!! Also I was told that for the first try starting it up I should go with a high octane fuel and even a fuel booster to help burn up some of the old fuel left in the lines. Any thoughts on that?
  #10 (permalink)
Old 05-20-2012, 12:59 AM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
jacks61ford is starting off with a positive reputation.
I would flush the tank and blow the lines out bad gas is bad news
  #11 (permalink)
Old 05-20-2012, 01:44 AM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Quote:
Yup, clean the whole fuel system and replace any rubber hoses. You might try just cleaning the carb. If it needs a kit you should try to find a tag or part number on the carb. My 60 has a Holley 2 bbl but I'm not sure if it's what came on there. I would probably use Marvel Mystery oil in the cylinders. Unless the rats have ate the plug wires, I'd just file and set the points until I heard it run, no sense in putting a bunch of new parts on an engine with a rod knock or dead hole(s).
  #12 (permalink)
Old 05-20-2012, 10:52 AM
Quote:
I've heard some say to use denatured alcohol when cleaning out old gas from a tank, but I'm not sure if that's best. It's been capped, but I won't know what the condition is inside there until I get it out of the truck. As far as the Marvel Mystery oil would putting some in the carb at the first start-up and even in the fuel be advisable? Or should I just put in each cylinder only with a good octane fuel? I read up a little on this stuff and it sounds like it works as a fuel additive. BTW there isn't any good way to repair a badly rusted radiator is there? I'm thinking it's best to just find a replacement for it. What would be ideal? I've seen some folks who have used one from an older F250, but I'm not sure what would be a good replacement without modifying anything. Oh crap am I in deep here!!!
PS: I'm too new at this to have any idea how to file and set points!!! I was planning on replacing the cap and rotor, but maybe I'll wait and see if she turns over first.
  #13 (permalink)
Old 05-20-2012, 08:30 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Nice truck and welcome to FTE! Tons of info around here. Enjoy your project! Glad someone has it that wants to do something with it!
  #14 (permalink)
Old 05-21-2012, 06:27 AM
Take your (empty) gas tank, with the sender removed, and your radiator to a good radiator shop. They can clean the tank and tell you if the radiator is savable, which they can also tank it and get it cleaned up if that's all it needs.
You've got a pretty good looking old truck, lots of us have started with way worse. Just sit back and enjoy the process, don't let it over whelm you.
  #15 (permalink)
Old 05-21-2012, 10:43 AM
Your right she's in really good shape and that's why I'm soo excited to jump into this project. I'm trying to pace myself and it's not easy!! First thing is I have to get through the end of the month, sister is getting married, and then I can get started digging in. It's gonna kill me to wait though. Thanks for the tips, I wouldn't have even tried to salvage the radiator, but it doesn't hurt to ask right! I would like to clean the tank myself to keep the cost down though.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
