Fun day in van Heck
Old 05-27-2012, 05:30 PM
jroehl's Avatar
jroehl
jroehl is offline
A screw-scissor jack can be VERY fast--you just have to put an impact wrench on the screw! But I don't like them because they generally have a very narrow base that makes them prone to tipping over if you don't have a very level, firm surface on which to work.
Jason
Old 05-28-2012, 08:26 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
An FYI on this screw-type scissor jack I mention from time-to-time and few photos:
Folded/stowed completely down its no more than 4" tall but a full 22" long---it'll fit under a very low jacking point like an axle or steering knuckle even with a flat tire. The base measures 5" x 8", has a bit of articulation to slightly accommodate a slightly sloping surface but I've never tested those limits!
It'll raise something a full 20", still have a bit of stability, enough to mount a flat tire. It seems to take forever raising something but the effort is very easy, most women and strong kid could crank it easily enough. It was never intended to be a service jack and I've never used it for that, more a peace-of-mind thing when on the road.
The business will accommodate a few different tools:
I'm posting this only because that term "screw-type scissor jack" probably conjures up something not quite as usable or as substantial as this one.
Old 05-28-2012, 03:23 PM
maples01's Avatar
maples01
maples01 is offline
When I was in rehab after my accident, I met a guy, a brother paraplegic, he was injured when a dump truck fell off of a jack on him, our life is far from easy, and makes you wish you were dead, so I can say safety first.
I've bought cheap parts, even the store brand stuff, on items that require time to replace, I save up for the name brands, brakes are a no brainer, how much is your life worth.
BTW my E-350 sinks the jack stands into asphalt, I had to knock them out with a pry-bar when done, amazing since it's relatively empty.
AXracer
07-07-2012 08:57 PM
bobbyrjw
58
10-26-2011 01:11 PM
Bill W
Arizona Chapter
31
07-01-2008 09:48 PM
mellowyellow55
03-03-2007 06:38 AM
Jupiter Coyote
1997 - 2003 F150
04-20-2004 01:54 PM
Quick Reply: Fun day in van Heck
