Rear axle pinion bearing replacement - Ford Truck Enthusiasts Forums
Old 05-19-2012, 07:16 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
I have a constant whne going down the road with foot on the gas. Back off and it quiets up. At 2-3 MPH i think i can here a " tick- tick". Took the drive shaft off, wheels off ground, cover off and oil out. Spin wheel and i can hear a tick - tick, i THINK around the pinion bearing. NO play up and down or in and out, but it appears to have 2-3 times the backlash i would expect. I used the screw driver- stethiscope--- still think its the bearing. This is a 9.75 axle. What kind of luck would i have pulling the yoke off and going in from the front without removing axles halfs and ring gear ? I thought i had read that here before. Never done one that way .
Old 05-19-2012, 08:57 PM
steve(ill)'s Avatar
im guessing the post i saw was for a seal replacement ? I can believe the bearing can be pulled out the front ?
Old 05-19-2012, 10:07 PM
Mickirig1 Mickirig1 is offline
Mickirig1 is starting off with a positive reputation.
If it's anyone of the trucks listed under your name. The axle really needs rebuilt with that many miles on it. Ring and Pinion, seals, spider gears, all bearings and C clips if it has them. You can buy complete rebuilt ones too. I think Jasper has them. You don't want to keep throwing parts into it. Unless the person know what they are doing. You can chew parts up in 50 or less miles. Then your back to square one. Still broke!
My 2004 FX4 5.4 has the infamous tick noise :'( Hoosiergirl 2004 - 2008 F150 11 09-20-2016 11:47 AM
2016 F-150 3.5 Ecoboost - weird ticking / clicking on acceleration. MikeDVB 2015+ F150 11 04-20-2016 05:08 PM
need help Aidansdaddy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 03-23-2015 07:11 AM
Please Help!! 2008 f150 5.4 ticking Problem. TrukProblemz 2004 - 2008 F150 5 02-10-2014 03:51 PM
428 Engine Tick Jayman1976 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 10-07-2013 01:15 PM
Tags
01, 03, 2002, 75, 77, aerostar, axle, bearing, end, explorer, f150, f250, ford, pinion, rear, replacement, sport
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
