1966 - 1977 Early Broncos
Timing off on 75 ranchero 400 engine.
Old 05-19-2012, 02:54 PM
chamblizi's Avatar
chamblizi
chamblizi is offline
Hey i am phil I found out my timing is really off right now.
I just changed spark plug wires and my idle just went completly down thus leading me to believe there is timing issue according to the paper work on how to do spark plug wires/firing order.
For my vehicle firing order is 1 3 7 2 6 5 4 8 which is a counter clockwise order.
Welp my vehicle acts as if it wants to start but then does not do anything so it goes... chrrr chr chrrr chr chrr poof chrrrr chrr chrrr chrrr chrrr
The wiring is 100% correct on my paper work and i wired it correctly.
How do i adjust the distributor so it fires at the right time. My distributor is actually crooked and on the paperwork it shows it perfectly aligned so that means my distributor is off by a few inches.
How do i know when my engine is TDC
Other information to be aware of i have a stock Vaccum advanced distubutor .....
Old 05-20-2012, 08:40 AM
chrlsful's Avatar
chrlsful
chrlsful is offline
400M in a 70s chero
Got the wrong form, friend.
I'm a 6 cyl guy so can't help. Look @ everything U changed B4 it stopped running. Did U change something w/the dizzy too? U may need to unclip the cap - it & turn it to match ur pic, then replace all the wires on it as in the other pic?
@ 178 posts U may not know how to find the right form 4 ur motor. Skip above the blue horizontal stripe to way up top where there's a horz. row of words - on this page. Click on "Forums" and scroll 2 find ur motor.
Good Luck.
Old 05-20-2012, 07:37 PM
chamblizi's Avatar
chamblizi
Good Luck.
ehhh man my whole vehicle is crap.... i only changed two things changed and i got too much stuff going on.... the whole engine working with that piece of garbage block is just not worth the time. i did everything i would normally do to my trucks... It is definitely not me... when i got the vehicle the vehicle is rigged all to hell and i know it.. If the vehicle was to specs then i would be able to do everything as described in books. I am no floozy when it comes to trucks but... man i am about done with it... not worth the effort to keep playing with replace the engine ...
Old 05-20-2012, 09:41 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
Kray-zeey
Don't go all radical on us, now dude. Let's C if we can't help U ...
Slow down'n tell us what u've done'n, what you've got. Let's figure it out...
Like I said, U may need another forum. But let's C....
what did u do after it was RUNNING PROPERLY?
Old 05-21-2012, 03:29 PM
chamblizi's Avatar
chamblizi
well, Lets just say i played around with it now it runs... now to figure out what is the issue causing extreme low idle...
I am thinking about draining offf all the fuel or run it thru then drop my tank clean it then go from there.
all my problems started when i got crappy gas from safeway...
Old 08-21-2012, 12:16 PM
iTod's Avatar
iTod
iTod is offline
Fuel pump, fuel filter however obvious that might seem.
gunner360
02-09-2018 07:35 PM
79half-ton
12-29-2011 12:28 PM
marksatterfield
3.8 & 4.2L V6
12-30-2010 07:47 PM
64F-100
04-05-2008 10:43 AM
Derrick1972
20
01-24-2004 03:03 PM
Quick Reply: Timing off on 75 ranchero 400 engine.
