98 f250 4x4 noise...help!
Old 06-23-2012, 04:15 PM
bro/dude's Avatar
bro/dude
bro/dude is offline
I'm a new Ford owner, when I engage 4wd I get a fairly annoying whinning / wheering sound that sound like the front end. Only makes sound under acceleration not coasting. No vibration at all. Any ideas would be great!
Old 06-23-2012, 04:28 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
Welcome to FTE!
What kind of surface are you driving on? If on pavement, STOP!
4wd is for limited traction surfaces, not wet pavement, never dry pavement and not even dry dirt or gravel.
Snow, ice, mud, loose hills--stuff you can't pull through in 2wd.
Old 06-23-2012, 04:34 PM
bro/dude's Avatar
bro/dude
bro/dude is offline
it makes the same sounds regardless of the type of terrain I'm driving over
Old 06-23-2012, 04:36 PM
85e150's Avatar
85e150
Same noise in low range and high range?
Old 06-23-2012, 04:39 PM
bro/dude's Avatar
bro/dude
bro/dude is offline
yes same noise and either low range or high range
Old 06-23-2012, 04:44 PM
85e150's Avatar
85e150
Check the oil in the diff first, then TC. Since it's the same noise, if it's in the TC, it may be the output shaft bearing, if it's the TC.
Can you run it for a while and check the cases for heat?
Do you have manual hubs? If so, does it make noise when the hubs are locked but the TC is in 2wd?
Old 06-23-2012, 05:03 PM
bro/dude's Avatar
bro/dude
bro/dude is offline
Just had tc fluid changed, oil in the dif was good, tech said it came out of the tc really hot, auto hub not manual.
Old 06-23-2012, 07:53 PM
85e150's Avatar
85e150
Did the tech find anything in the oil? Did it make the noise before the oil change?
This is the stage in internet diagnosis where we start grasping at straws.
Perhaps you could pull the front DS, put it in 4wd and give it go--see if the noise changes, or if the output on the TC gets hot.
Usually someone with this same problem comes by here about 2AM, so stand by.....
Old 06-23-2012, 08:03 PM
bro/dude's Avatar
bro/dude
bro/dude is offline
Yes the noise was there before and after the tc service. Nothing was noted about the fluid other than ot was broken down and really hot.
Old 06-23-2012, 08:11 PM
85e150's Avatar
85e150
TC = Transfer case, right? TC should not run "hot" and break down the oil. Takes a lot to break down 90w gear oil methinks.
If it's not shedding metal into the oil, maybe you live with it and see what happens unless you want to pull the TC and go through it.
Perhaps a better idea will pop up.
Old 06-23-2012, 09:00 PM
bro/dude's Avatar
bro/dude
bro/dude is offline
Thanks either way ill prob run it till it blows out...idk its a Ford the reason I had so many Toyota's before this truck.
Old 06-23-2012, 09:20 PM
85e150's Avatar
85e150
Well, you can't pin troubles with a '98 on Ford at this date. Who knows how it was take care of, and what was done with it....
itguy08
2009 - 2014 F150
02-10-2014 03:47 PM
1FlatbedAmbulance
35
10-06-2012 08:21 AM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
04-29-2012 07:41 PM
jsmallwood_2000
1997-2006 Expedition & Navigator
07-04-2009 10:43 PM
theoshin
Modular V10 (6.8l)
02-04-2008 08:17 AM
Quick Reply: 98 f250 4x4 noise...help!
