Folding Mirror Question - Ford Truck Enthusiasts Forums
Old 05-19-2012, 08:21 AM
jpollesc jpollesc is offline
jpollesc is starting off with a positive reputation.
Has anyone had issues with their mirrors folding in? One of mine makes a popping sound and will not fold in or out. I can hear the motor running, sounds like a gear is out of alignment. Have tried to reposition manually with no luck. Is there a rebuild kit for the internals or will I need the entire mirror assembly?
Thanks.
Old 05-19-2012, 08:23 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
you mean the glass, not the mirror head.. ?
the arm is designed for mechanical release, so if it gets hit by something, caught on something you can fold/unfold it manually.
I haven't seen any reports of the glass not moving..
no reports of replacement parts smaller than the whole arm & head.
sam
Old 05-19-2012, 08:26 AM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
I think he means the entire mirror power folding into the side of the truck.
Is your truck out of warranty? If it isn't out of warranty, then talk to the Parts Dept at the local Ford dealership. They might be able to hook you up. Please post your findings though as my folding mirrors get used daily. I'm waiting for the day when mine start giving me grief. My truck won't fit into the garage unless I fold the mirrors in.
Old 05-19-2012, 08:31 AM
Yes, the function that swings the entire mirror head in towards the windows to prevent contact at the bank drive thru. Functions by pulling back on the small stalk that adjusts the position of the mirror glass.
Old 05-19-2012, 08:59 AM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion Tuxedo Scorpion is offline
Tuxedo Scorpion is gaining momentum as a positive member of FTE.
in my 08 6.4 there was a time when a passing truck and i had a quick handshake of mirrors. not only did my mirror fold back but the glass popped out and was hanging. i thought for sure i just bought a new assembly. got home. cooled off. then re installed the glass without any difficulty or issue. then pushed the mirror back into position. i noticed it didnt feel the same, as if it didnt lock into place. then when driving (especially at high speed, it would start folding back due to the air load. i read up on it in my manual and found out there is a cam system and that activating the power fold function several times would re align the cam itself. sure enough, after a few power fold cycles, back to normal.
hope that helps.
Old 05-19-2012, 09:04 AM
farmerdave farmerdave is offline
farmerdave is gaining momentum as a positive member of FTE.farmerdave is gaining momentum as a positive member of FTE.
My power fold mirror on the drivers side stopped working for a day and then magically started working the next day. Maybe a bug or piece of mud jammed the mechanism.
Old 05-19-2012, 09:14 AM
oh one more thing they also have an auto disable feature, if they are activated too many times in too short of a period, they disable so they dont overheat.
Old 05-19-2012, 10:47 AM
jermort's Avatar
jermort jermort is offline
jermort is starting off with a positive reputation.
Quote:
hope that helps.
Same thing happened to me only on the passenger side. Big noise when made contact with the explorer I met up with at a stoplight. Thought I'd sideswiped the whole thing. Mirror folded back, didn't pop the glass. Explorer did not fare as well, had to buy them a new replacement glass. Manually folded the mirror back out and the power fold worked the first time, never a problem.
I am way more careful in those tight left turn lanes now.
jammer
Old 05-20-2012, 11:43 PM
Thumbs up
Cycling the power fold function 7-8 times and it started working again. It made some rather uncomfortable popping sounds and got stuck several times during the process. Good engineering from Ford that these will relearn the positioning instead of stripping the internal gear mechanism.
Appreciate the advice.
Old 05-20-2012, 11:47 PM
The noise was the cam system re aligning itself. Yes its a neat system.
Old 05-21-2012, 11:23 AM
2horses's Avatar
2horses 2horses is offline
2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.2horses has a great reputation on FTE.
My passenger mirror moves faster, both folding and unfolding, than the driver's side does - anyone else have this?
Old 05-21-2012, 11:37 AM
Docindahouze Docindahouze is offline
Docindahouze is gaining momentum as a positive member of FTE.Docindahouze is gaining momentum as a positive member of FTE.
Quote:
yes mine is the same way. passenger side is always faster when folding and unfolding. it's okay though for me as long they work proper.
Old 05-21-2012, 11:43 AM
Says in the manual one side may go faster than the other and that is normal.
Old 05-21-2012, 11:57 AM
2horses's Avatar
Well who the heck reads the manual??????
Obviously not me. You are a veritable encyclopedia of manual knowledge, Tux!
Old 05-21-2012, 12:17 PM
I love reading manuals..
Power fold mirrors stopped working MikeRizz 6.4L Power Stroke Diesel 8 11-20-2015 02:18 AM
Power fold mirrors wader250 6.7L Power Stroke Diesel 10 08-08-2015 02:53 PM
2015 F250 power folding mirrors Husky44 1999 to 2016 Super Duty 2 05-08-2015 03:22 PM
power folding mirror wiring questions SUPERDUTY_08 1999 to 2016 Super Duty 0 03-07-2015 08:56 PM
Help! Smashed power fold mirror housing davearx 1999 to 2016 Super Duty 10 01-01-2015 09:38 PM
Tags
07, 2001, 2009, 2011, 450, expedition, f250, flat, floor, fold, folding, ford, mirors, mirror, mirrors, pushed, retractable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
