Folding Mirror Question - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-15-2012, 12:12 PM
bnmccoy's Avatar
bnmccoy bnmccoy is offline
bnmccoy is gaining momentum as a positive member of FTE.bnmccoy is gaining momentum as a positive member of FTE.
Somebody posted that the outside air temperature sensor is on the bottom of the passenger mirror. I don't think it was there on my 08. Some tidbits from service manual...
C650 Ambient Air Temperature (AAT) sensor; (on bottom of passenger mirror).
Ambient temperature sensor (optional can be serviced separately from the mirror)
When the vehicle is started using the remote start feature and the outside temperature is less than 0 C (32 F), the heated mirrors will be activated. No climate control adjustments are recognized during remote start operation. Once the ignition is cycled to the ON position, the climate control system returns to the previous settings
  #32
Old 09-17-2012, 01:14 AM
Adventure Rider's Avatar
Adventure Rider Adventure Rider is offline
Adventure Rider is gaining momentum as a positive member of FTE.
Assuming we live on a perfect world, can I add the extended power mirrors to my truck
I am assuming as I have the XLT package the mirrors do not have motors so I would need to orders those.
If I were to order them are all the harnesses in place already so I just have to plug and play?
This would also pertain to the drivers door mounted control switch
Is what i am proposing even feasable?
  #33
Old 09-17-2012, 09:09 AM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Anything possible if you want to put the time & money into it.
I don't think it's just a matter of adding the motors. You'd be better off ordering the complete unit that power folds and extends. You Probobly won't be able to tie into your existing mirror adjustment stick because your truck didn't come with them, but this will give you the opportunity to install them how you wish. Maybe set them up to open/close with the ignition on/off or something. Just a thought.
  #34
Old 09-17-2012, 09:42 AM
Thanks RM
Probably right on the mirror set up - need to check $$$ and scare myself
Second would be the revised switch
Do you think the truck would have the harness to connect to and it just isn't?
  #35
Old 09-17-2012, 10:05 AM
Hdslider's Avatar
Hdslider Hdslider is offline
Hdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputationHdslider has a superb reputation
It may have connector. But i can tell you u must buy mirror assemblies and wiring harneses and switch. Mega bucks.
  #36
Old 09-17-2012, 12:07 PM
Rod Bensken Rod Bensken is offline
Rod Bensken is starting off with a positive reputation.
Quote:
Mega Bucks is correct. When they replaced mine under warranty, the said the mirror assembly was 1700 bucks. I don't know if 3-4 grand is worth it, but is is real nice.
  #37
Old 09-17-2012, 06:18 PM
Quote:
wow - this may need a rethink
  #38
Old 05-15-2015, 12:40 AM
Ace_boy2786 Ace_boy2786 is offline
Ace_boy2786 is starting off with a positive reputation.
Quote:
Originally Posted by Docindahouze View Post
yes mine is the same way. passenger side is always faster when folding and unfolding. it's okay though for me as long they work proper.
Well, This is exactly what i was looking around for; I guess I will just have to put up with the annoyance (slight case of OCD maybe) of them folding at different rates.
For those asking if You can put these on your truck that they didn't come on, The answer is going to be yes, You can, Maybe with a little wiring work; Heck, I have a 2005 and I just put these 2012 mirrors on mine and aside from having to re-make the wiring adapters I had made (First time didn't turn out too good, But functional for the most part) they are on and working. As for price point, I payed 7xx.xx and 8xx.xx/Mirror, IIRC, and that is the "discounted" price you get from Auto Nation White Bear Lake (Tousley), plus the price of the Paint-able/Chrome cap and paint if you go that route; If I'm not mistaken, I believe the list price was around 1200.00/mirror.
P.S. Ohh, Old thread.... sorry for the revive, but Thanks for the info.
  #39
Old 03-25-2016, 10:45 AM
trikerjim trikerjim is offline
trikerjim is starting off with a positive reputation.
Help ! loose mirror heads.
I have a 1999 E-450 and my mirror heads keep going out of adjustment Can any one tell me how to adjust the %$@^& things. or do I need to replace them as I have read others doing on this thread? And if so, what mirrors would be best as these are on an RV with a great 7.3 Power Stroke with very low miles. Thanks in advance. My apologies in advance if I posted incorectly but I have to fix my mirrors so's I can leave.
Have a Happy Easter to 1 & All
Jim :aka- trikerjim
  #40
Old 03-25-2016, 12:35 PM
my_crib_too's Avatar
my_crib_too my_crib_too is offline
my_crib_too has a brilliant futuremy_crib_too has a brilliant futuremy_crib_too has a brilliant futuremy_crib_too has a brilliant futuremy_crib_too has a brilliant futuremy_crib_too has a brilliant futuremy_crib_too has a brilliant futuremy_crib_too has a brilliant futuremy_crib_too has a brilliant futuremy_crib_too has a brilliant futuremy_crib_too has a brilliant future
Jim :aka- trikerjim
Welcome to FTE....
  #41
Old 03-25-2016, 10:24 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
I didn't read all these but y'all who need replacement start checking craigs list. haven't seen any here right now but I was down in fort myers fl all winter and there were several for sale for 2 to 3 hundred for the pair. I think they are the same from 08 on.
  #42
Old 03-25-2016, 11:39 PM
Just Strokin Just Strokin is offline
Just Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to beholdJust Strokin is a splendid one to behold
Jim :aka- trikerjim
If you have the power folding mirrors,, check this video from Ford on how to sync them and stop the fluttering of them in the wind...
  #43
Old 01-03-2017, 02:29 PM
roadkingtc88 roadkingtc88 is offline
roadkingtc88 is starting off with a positive reputation.
Newer mirrors
Hi. Looking at the new models, and power fold is a must. We use it daily on our '08 F150. With the current truck, you can power fold them in anytime, key in or out, However, the new ones don't seem to work with key out, at least the new ones on the dealer lot. Has Ford changed that circuit? Or am I missing something?
  #44
Old 01-03-2017, 03:38 PM
My 2015 folds without the key.
  #45
Old 01-03-2017, 03:47 PM
Ford chat says the ign must be on. Not that I don't believe those manning the chat service, but I'll try it myself next visit to dealer, now that I know how to work the new controls.
Power fold mirrors stopped working MikeRizz 6.4L Power Stroke Diesel 9 01-25-2017 11:28 AM
Powerfold mirrors quit Larry NCKS 1999 to 2016 Super Duty 5 11-20-2015 02:09 AM
Power fold mirrors wader250 6.7L Power Stroke Diesel 10 08-08-2015 02:53 PM
2015 F250 power folding mirrors Husky44 1999 to 2016 Super Duty 2 05-08-2015 03:22 PM
power folding mirror wiring questions SUPERDUTY_08 1999 to 2016 Super Duty 0 03-07-2015 08:56 PM
Tags
07, 2001, 2009, 2011, 450, expedition, f250, flat, floor, fold, folding, ford, mirors, mirror, mirrors, pushed, retractable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
