Disk brake conversion
Hey guys,
I know its been covered by all the forum and write ups etc. I've been looking around today and found that I can't seem to source a used 76-78 Caddi Eldorado rear caliper with a park brake provision, with a manual it is necessary. I can get them new, but they are about $320 dollars or so which is a bit high.
Why is it that I couldn't run an e-series van rotor, with hydroboost setup and superduty calipers?
I'd assume that the parking brake issue would be the biggest, but I can source those for about $70 per, which isn't bad at all.
Received 3,107 Likes
on
on
Ford Sterling Disc Brake Bracket 84-94 - RuffStuff Specialties
this is what im gonna run
with a micro lock
Brake Locks
with a micro lock
Brake Locks
Hey guys,
So I've spent all my time looking over these threads again.
It appears that I could swap in a superduty axle front and rear. Should I choose to use this option and they have all the hardware and I bought 8x170 wheels it would be a swap and go with parking brake?
What exactly is it that makes a van or superduty park brake not work when I swap the associated rotors, calipers etc over? Basically how much of my stock park brake assembly can I use?
So I found a guy who has all the parts from an eseries van, flange, park brake assembly, rotors, calipers etc. So given that the flange is already off the Dana 60 van axle it would appear that I would simply remove the flange from my axle and grind everything smooth and then slip the van flange on, weld and go? Or is the flange between axles a different size and i would have to have the dana flange milled out to fit?
1972fordhighboy2
10-23-2015 10:05 PM
TonyJestis
11-06-2012 01:36 PM
73F100*8Mile
10-05-2007 08:50 PM
ksmith203
12-16-2006 03:14 PM
