1950 ford truck 6 volt or 12 volts
It came from the factory 6 volt positive ground, many change to 12 volt for modern radio and light systems, never heard of a 9 volt battery except the ones in smoke dectors. But there is an 8 volt thats the size of a 6 volt, gives more cranking power, but without tweeking the voltage regulator the generator won't charge it propperly.
on
Had good redults with an 8V battery years ago in an old straight eight Pontiac but really 8V is a band-aid approach if you are having starting problems. It can cause shortened bulb life and you need to have the voltage regulator adjusted as suggested. The best approach is a full on change to 12V.
The following users liked this post:
on
Agreed, but I'd rather deal with them and have a few dollars in my pocket than pile the stuff up behind my garage.
Speaking of stuff piled up behind the garage, I recently gave away a 49 F-1 front axle, rear end, front springs, and a couple of 16 inch wheels and tires from my old 48 F-3 through a Craigslist ad. The guy I gave it to is building a rat rod and was happy to get it. I gave up trying to sell that stuff locally and it's too bulky to sell on Ebay...
Give me a bit and I can give you the name of a shop in SW Colorado that will buy core generators and starters. After shipping I think you get about $20 each.
I have a 43' Ford GTB bomb truck that I would like to change to 12 volts. The starter is the only real problem I think. I think there is a shop near me that can rebuild the starter to 12 volts but is there any way to use a resistor to crank it over to try and get it running? This truck is a back burner project but I am always looking for info.
Joe
Joe
Joe
Joe
Straight 12v won't hurt it. People have been running 6v starters on 12v for years with no issue. You just don't want to be cranking it for a long time without a cooling off period. It does put a little more wear on the bendix and flywheel teeth, but usually there is a reduction in crank time, too.
