1950 ford truck 6 volt or 12 volts - Ford Truck Enthusiasts Forums
Old 05-19-2012, 01:55 AM
beckman beckman is offline
beckman is starting off with a positive reputation.
hi guys i had a question about a 1950 ford truck is that a 6 volt system or 12 volt system and could you use a 9 volt battery instead of a 6 volt battery thank you everybody
Old 05-19-2012, 06:57 AM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
It came from the factory 6 volt positive ground, many change to 12 volt for modern radio and light systems, never heard of a 9 volt battery except the ones in smoke dectors. But there is an 8 volt thats the size of a 6 volt, gives more cranking power, but without tweeking the voltage regulator the generator won't charge it propperly.
Old 05-19-2012, 08:07 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Had good redults with an 8V battery years ago in an old straight eight Pontiac but really 8V is a band-aid approach if you are having starting problems. It can cause shortened bulb life and you need to have the voltage regulator adjusted as suggested. The best approach is a full on change to 12V.
Old 05-19-2012, 02:30 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Or make sure that all of your wiring is good and have thick battery cables. Don't buy the cables from the store, they're junk for 6v systems. You can make cables out of 1/0 welding cable. Also, 6v electrical systems love good grounds. Make sure all of your grounds are clean and tight.
Old 05-19-2012, 10:33 PM
jat4's Avatar
jat4 jat4 is offline
jat4 is starting off with a positive reputation.
x2 on thick battery cables for 6v system. I swapped out what I had with some 2/0 battery cables I got on ebay, and the difference in starting is night and day. Could not believe the difference it made.
Old 05-19-2012, 11:15 PM
51PanelMan's Avatar
I'm lucky in that I have a friend that's a shop foreman for a large equipment rental company. He's the one that made the cables for my 52 and my Airflow. You're right about the difference thicker cables make.
Old 05-29-2012, 08:51 PM
straws straws is offline
straws is starting off with a positive reputation.
So what happens when we convert to 12 volts? What do we do with the left over generators, regulators, and fabric wiring? Is there anything other than boat anchor status for the generator, and can the other parts be used again? The generators weigh a ton!
Old 05-29-2012, 09:18 PM
Quote:
Put them on Ebay. Someone will want them...
Old 05-29-2012, 09:32 PM
Sadly ebay is too subjective and hard to deal with for some things.
Old 05-30-2012, 01:28 AM
51PanelMan's Avatar
You can have your existing generator rebuilt into a 12v alternator. Your existing wiring will be fine unless it's old and frayed. Regulators should also be ok.
Old 05-30-2012, 08:03 AM
Agreed, but I'd rather deal with them and have a few dollars in my pocket than pile the stuff up behind my garage.
Speaking of stuff piled up behind the garage, I recently gave away a 49 F-1 front axle, rear end, front springs, and a couple of 16 inch wheels and tires from my old 48 F-3 through a Craigslist ad. The guy I gave it to is building a rat rod and was happy to get it. I gave up trying to sell that stuff locally and it's too bulky to sell on Ebay...
Old 05-30-2012, 10:35 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Give me a bit and I can give you the name of a shop in SW Colorado that will buy core generators and starters. After shipping I think you get about $20 each.
Old 05-30-2012, 11:02 AM
Blythewoodjoe Blythewoodjoe is offline
Blythewoodjoe is starting off with a positive reputation.
I have a 43' Ford GTB bomb truck that I would like to change to 12 volts. The starter is the only real problem I think. I think there is a shop near me that can rebuild the starter to 12 volts but is there any way to use a resistor to crank it over to try and get it running? This truck is a back burner project but I am always looking for info.
Joe
Old 05-30-2012, 01:24 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
Joe
Straight 12v won't hurt it. People have been running 6v starters on 12v for years with no issue. You just don't want to be cranking it for a long time without a cooling off period. It does put a little more wear on the bendix and flywheel teeth, but usually there is a reduction in crank time, too.
Old 05-30-2012, 01:44 PM
Quote:
A mechanic friend of mine told me this too, the problem I am having is trying get this thing checked out with out spinning it over a lot. It's been sitting for 15 years or so. I thought about taking the plugs out and rigging up a belt over the back of the trans. and running it with a 110 volt motor, just to try and check out some of the components. I'm not a purist so I plan to put an alternor on it instead of the generator and put a 12 volt coil too. The rest of the wiring is shot any way. This truck is simple. Thanks, Joe.
battery generator problems easyrider47 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 09-15-2014 07:21 PM
6 volt tail lights easyrider47 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-23-2014 06:53 AM
Newbie question: 6 volt vs. 12 volt system Jacnat 1948 - 1956 F1, F100 & Larger F-Series Trucks 68 07-20-2014 04:36 PM
battery on 6 volt system?? 1950fordf2 Electrical Systems/Wiring 5 03-15-2013 12:08 PM
Help on 6 Volt to 12 Volt conversion chicken1 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-07-2011 12:57 PM
Tags
12, 12volt, 1950, 50, 6volt, battery, conversion, convert, converting, f1, flathead, ford, removal, starter, truck, volt, wiring, years
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
