76 SWB 2wd build
Prep work
The body was pretty solid except for the floorboards. I had to have the pass door skinned because of a dent... A few dings here and there, nothing major. A friend of mine is doing most of the work in his shop - the truck sat in my yard for 12 years and I have had 3 kids since then... I figured the only way it would get done before I retire was to enlist some help
Engine
For the motor, I ended up getting a 1995 351w roller motor from a Bronco. I took it all apart and checked it out, I was told it only had 30k miles on it when the Bronco was totaled. That looked to be true. Just had to hone it and put some new pistons in. I also changed the cam while I was in there.
Here is what it looked like when I picked it up:
The guy I picked it up from was going to use it in a Bronco he was restoring so it already had a carb intake - bonus for me!
Looking a bit better I'd say!
Currently...
Some paint is on some of the body. I ended up going with a metallic dark green. I looks much better in the sun (I will get some pics later and post).
A summary of what I have changed on the truck:
- Went from a 300ci\C4 to a 351w roller motor with a WC T5
- Added air conditioning from a 1977 donor
- Power steering
- Power brakes
- Tilt wheel
- Changed color from baby blue to emerald green
I am hoping to have it on the road before summer's end! I am currently working out some dents on my grill shell.
- Power steering
- Power brakes
- Tilt wheel
I picked these (15" x 8.5") up today for $100 of craigslist for my project! They are in good shape and should clean up nice... From what I could tell these are A-Team Cyclone ii wheels. I have heard them called turbine, western and fins but whatever they are called I like them
Headers
- Power steering
- Power brakes
- Tilt wheel
- Power steering
- Power brakes
- Tilt wheel
Did the spacer go in to raise the back of the trans? Yours looks to sit higher than mine. I used a1 inch spacer to raise the back of mine.
