weird noise after sct sf3 tune
egr has been deleted for sum time now. Just got aroung to purchasing a sct sf3 tuner. after installing the tow hall tune i have a weird noise. kinda sounds like the intake or maybe turbo going... woof woof woof... when i let off the excellarater. It only does it when the boost gage reaches 20 psi, i let off the excellarater i get the ... woof woof woof sound.
Anyone have any ideas as to what this could be????
Wierd Noise
Is this a 6.0? If it is than the noise is your variable turbo housing unloading pressure when you let up on the gas pedal.
I had a 6.0 and the first time I towed a heavy trailer it scared me when it made a big noise as I let up on the skinny pedal.
If it is a 7.3 then I don't know nothing.
Some call it turbo farting..Could be the vanes are sticking. Solution is to remove and clean the turbo..If you check down in the 6.0 diesel forum look in the tech. section. There is all the info needed to remove and clean the turbo, with lots of photos..If you need any advise the folks there can help you out..
on
That I can understand and it makes sense considering what a programmer does. However, not doing it period with a stock tune, either the conditions aren't being totally replicated correctly or it's a different noise.
