Will Mechanical heat gage effect computer
Old 05-18-2012, 05:36 PM
T Denning's Avatar
T Denning
T Denning is offline
Cool Will Mechanical heat gage effect computer
1989 E-150 5.8 conversion van 90,000 miles
My heat gage rides on the high end of the gage. I bought a mechanical temp gage to install. Then I got to thinking, will disconnecting and removing the electrical temp sender affect the vehicle's computer?
I have read on this site where the original stock Gage might not be very accurate.
I have only had this van for three weeks and the former owner (an elderly good frend) said it has always run hot.
I just replaced a thermostat and a fan clutch new plugs and wires. The waterpump and rad were replaced a few years back.
We are already in three didgets here in the northwest Phoenix area.
Thanks for your help,
Old 05-18-2012, 07:22 PM
econolinemanor's Avatar
econolinemanor
econolinemanor is offline
OBD-1 computer has two temp units, one for the computer (Sensor) and one for the gauge (Sender) Your better off getting a new Sender for the gauge first. Then later install the mech gauge as a (stand alone) without unhooking things........
Old 05-19-2012, 07:55 AM
2000Ford2000's Avatar
2000Ford2000
2000Ford2000 is offline
If you see no signs of actual overheating, then don't worry about it. These gauges are crap from the start.
If you are driving it, and it's over 100 and it's not blowing water out, you're OK.
Do you hear the fan engaging? It should be pretty loud, even in the cab. It may not actually be getting hot enough to engage. Realize that those Ford gauges cost them about 10 cents each. My 88 7.5 always showed high too, but it wasn't real I came to find out.
Old 05-19-2012, 08:06 AM
PStruwing's Avatar
PStruwing
PStruwing is offline
Do not worry about you gauge, my 89 Mustang has an Autometer Water temp gauge added in a different spot and it comes up more slowly than the idiot needle gauge in the dash which is still connected.
The 2 only agree the motor is warm after a few min. I have the Autometer needle gauges added on because the factory idiot gauges are way to slow to tell me I have a problem.
Old 05-19-2012, 06:06 PM
T Denning's Avatar
T Denning
Thanks for the reply fellows.
I changed the temp sender and the gage came down.
I would still like to install a mechanical gage down the line if I keep the van.
Now an oil leak is my next challenge.
I can't remember how long it's been since I had a vehicle with the dimmer switch on the floor
Old 05-19-2012, 07:35 PM
econolinemanor
Glad your all set! atleast the starter isn't on the floor......LOL
Old 05-20-2012, 09:21 PM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
FWIW, on my e350, 195* reads somewhere between the M-L range of the gage, depending on what direction the wind is blowing (or some other factor we can't identify). once after i installed the gage, i saw a temp of 210 according to my autometer, and the stock gage was about one letter past the L. so i said "what the L", nothing to worry about
08-08-2012 09:44 AM
agryphon
1983 - 2012 Ranger & B-Series
19
12-24-2005 12:13 AM
willym
1999 to 2016 Super Duty
11-21-2005 10:33 AM
KC10Chief
04-22-2005 08:48 PM
gameboynws
03-10-2005 10:09 PM
Quick Reply: Will Mechanical heat gage effect computer
