Power window problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-18-2012, 03:30 PM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
I have a 2004 F350 Lariat crew cab. The front passenger power window will go down but not up. Checked the connector at the motor with a test light and there was juice on each wire depending on which way the switch was thrown. Figured the motor was bad, so I installed a new one but nothing changed. I did notice the window would go down, down only not up, when you used the master switch in the driver's door. It does nothing using the switch in the passengers door. Tried to disassemble the pass door switch and noticed it has a circuit board and is not a simple switch. Could the problem be in either the master switch or the pass door switch? Thought for sure a motor would fix the problem since it was getting current.
Old 05-18-2012, 06:31 PM
V10ZILLA's Avatar
V10ZILLA V10ZILLA is offline
V10ZILLA is gaining momentum as a positive member of FTE.V10ZILLA is gaining momentum as a positive member of FTE.
I wouldnt think it was the motor as the motor was used to lower it. It sounds like a switch problem....I think there is a thread on here on how to fix the switch yourself, or maybe the thread was for the door locks. i will try to find the thread and attach it. but as of now it sounds like a switch or a relay issue as you said both the driver door switch and passenger door switch are doing the same thing regarding the passenger door window.
Well there are alot of threads regarding all sorts of issues of what you are talking about. Just use the search box on here and you will have to read through them. Uless someone can chime in and knows from experience exactly what your issue is..
Old 05-19-2012, 06:27 AM
Did a search. Couldn't find one with my exact problem. The motor will go down but not up. I have current going to both wires at the motor. One wire when the switch is pushed for up and current on the other wire when the switch is pushed for down. Since there is current at the motor I thought it was reasonable to blame the motor.
Old 05-23-2012, 07:44 PM
Pulled the motor and did a bench test. It worked both ways. Did a continuity between the master switch and the door switch using the wire color coding as a guide. Everything checked out. The only thing left was the master switch and once that was replaced the window worked in both directions.
Old 05-25-2012, 02:24 PM
spongecop's Avatar
spongecop spongecop is offline
Semper Fi
spongecop is gaining momentum as a positive member of FTE.
I have s similar problem but sommehwat different. My right rear winbdow will not go down with the master switch...only up. It works fine in either direction with the switch on that door. switch masters with a buddy same problem. Switched door switch same problem. Traced mine to a break in the harness at the door jamb. jumper the wires fgoing to the door and see if you can pin point where the break is. Its a common problem on these trucks.
Old 05-25-2012, 05:31 PM
The continuity test eliminated a broken wire. The master switch was the problem. Thanks for the input.
Old 05-25-2012, 11:20 PM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
just got mine going again with a little wd. the window lock was sticking in the lock position... and the rear pass door switch was sticking... working all the way around now.
mine may have just had gunk in them or something... i did t even check them with a meter or anything.
xtof
1990 power window(s) work sometimes Kendal 1987 - 1996 F150 & Larger F-Series Trucks 7 05-10-2016 12:50 PM
86 power window question Plowboy34 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-14-2016 06:03 PM
Power window mystery? Dpan63 1968-2013 Full Size Vans 3 04-09-2014 05:42 AM
Power Window Issues Bronco_Daddy Excursion - King of SUVs 1 04-04-2012 08:46 PM
[b]97 Xlt Power Window Problem[/b] vicv Explorer, Sport Trac, Mountaineer & Aviator 3 05-01-2005 04:26 PM
Tags
duty, f250, f350, ford, passenger, power, problem, problems, sport, ssuper, stuck, super, switch, trac, trucks, window, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
