Will an 8.8 fit in my 1965 F100??? - Ford Truck Enthusiasts Forums
Old 05-18-2012, 03:21 PM
Waylon Fan Waylon Fan is offline
Waylon Fan is starting off with a positive reputation.
I have a 8.8 from a 96 explorer will it fit in my 1965 F100? Any advice on how?
Old 05-19-2012, 10:01 AM
? I'm not sure
Old 05-19-2012, 07:46 PM
thechief66's Avatar
thechief66 thechief66 is online now
thechief66 is gaining momentum as a positive member of FTE.thechief66 is gaining momentum as a positive member of FTE.
Quote:
Different wheel bolt pattern to start with.
F100=5 on 5.5"
Explorer=5 on 4.5"
Why would you want to do this?
Old 05-19-2012, 07:52 PM
rustywheel68 rustywheel68 is offline
rustywheel68 is starting off with a positive reputation.
the Explorer 8.8's are a little narrow- a Crown Vic (pre-2003) would be a better choice.
but like the previous poster said, you've still got to deal with the different bolt pattern.
Old 05-19-2012, 08:36 PM
jhooch's Avatar
jhooch jhooch is offline
jhooch is gaining momentum as a positive member of FTE.
Agree with above, the 9 inch is a better rear end, they 8.8 is a c-clip axle retainer rear end. There are better ways to get disc brakes.
Old 05-20-2012, 12:15 AM
Thanks for the feed back, I have had a lot of luck in the past with an 8.8 that is why I went with it, and to get disk brakes also
Old 05-22-2012, 09:29 AM
Is the crown Vic a direct bolt in? Will any bolt in?
Thanks
Old 05-22-2012, 09:53 AM
Thanks
Do I even need disk on the rear?
Old 05-22-2012, 09:57 AM
jacks61ford's Avatar
jacks61ford jacks61ford is offline
jacks61ford is starting off with a positive reputation.
none I am aware of are bolt in I just put a Pre 2003 crown Vic rear in my truck and after cutting the coil stuff off it's as simple as putting the leaf pads on I am even using the sway bar
Old 05-22-2012, 10:07 AM
Quote:
How strong is the Vic rear end? where did you get one?
Thank you for the information
Old 05-22-2012, 11:18 AM
No, not really- unless maybe you're driving through a lot of water, or in the mountains.
The stopping power of the drums is perfectly fine.
If you've got a functioning 9" back there now, I wouldn't mess with it.
Old 05-22-2012, 11:41 AM
I have the donor to put disk on the front. ithink i will leave the back alone? I have a 74 F100 do you know if the power brakes and steering will work in the 65 F100
I am going with a 460 with a C6
Old 05-22-2012, 01:57 PM
yes, i'd leave the back alone.
the 74 steering and brakes should bolt up. you'll need to swap the column, or cut yours down some.
lots of info about that on the site, here's a tech article:
Power Steering & Disk Brakes 2wd 65-72 .: Articles
Old 05-23-2012, 09:25 AM
Thank you for the article, it is very detailed
Thanks again!
Old 08-30-2012, 10:34 PM
itsnotanova's Avatar
itsnotanova itsnotanova is offline
itsnotanova is a splendid one to beholditsnotanova is a splendid one to beholditsnotanova is a splendid one to beholditsnotanova is a splendid one to beholditsnotanova is a splendid one to beholditsnotanova is a splendid one to behold
If you switched the front to a crown vic suspension, then your bolt pattern would be the 5x4.5 pattern like the explorer 8.8 rear. It's what I'm doing. Just picked up a cv front today and it only had 10,000 miles on it. $200 for it
WTB 1965 F100 Horn 1965F100(3onthetree) WTB - Ford Trucks & other vehicles 5 11-19-2014 04:25 PM
Where Wheel Trim Rings Available for 1965 F100? 1965F100(3onthetree) 1961 - 1966 F-100 & Larger F-Series Trucks 7 07-28-2012 11:13 PM
1965 Ford F100 SWB bed, will any others fit? Invader6 1961 - 1966 F-100 & Larger F-Series Trucks 27 03-11-2012 10:59 AM
Bumper F100 1965, what! kevinfelix 1961 - 1966 F-100 & Larger F-Series Trucks 5 03-01-2011 05:12 PM
How many gallons is the stock gas tank on a 1965 F100 1965TwinIBeam 1961 - 1966 F-100 & Larger F-Series Trucks 9 02-12-2009 10:56 PM
Tags
1965, 1983, 65, 73, 88, bolt, engine, f100, f150, fit, ford, pattern, rear, truck, v8, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
