Van MPG's are in......might as well get a 460....sheesh!
Really?? Even when i was NA i had no problem hitting 100+.. it was going up hills that it didnt like. Now being turbod, it feels as if it doesnt even start pulling hard till about 60 in in 4th gear with my gears give or take 2200rpms and it just pulls and pulls
Well I installed a new Rad Cap, and upper rad hose today, and new Sunpro water temp gauge.
She runs right on 190* highway or intown. If I let it idle more than 2 min, temp starts cooling down under 190*
And bad news......
Found my oil leak.... and it isn't "only" the oil cooler. It's the drivers side head gasket! The back half, is seepin oil down the block. Leaking a quart every 150 miles... so it's pretty bad.
So now I'm gonna continue driving it as is, and see what I do.....I really don't feel like doing head gaskets in a van....again, especially not in this thing.
And bad news......
Will the oil cooler on the trucks fit the 86 Vans? I ask this cause when mine went out I found one for fifty bucks but didn't get it because it looked different. I had it welded up in stead. Thanks,
I didn't know the 6.9L had the oil plugs? I thought it was for the HPOP on the powerstrokes. Mite want to make sure it isn't that thats leaking then.
Chet
Chet
Well, I filled my front tank up to the brim last week and I have put about 125 miles on it since. I am at 3/4 of a tank according to my fuel gauge. I estimate getting a maximum of 250 miles out of this tank of fuel and that is being generous. Let's assume it uses 18 gallons of fuel. That comes out to about 13.8MPG. I did idle it for at least an hour and a half while I have been dick'n around with my A/C system but still, look at the specs on my truck. I have 3.55s, E4OD, Banks Sidewinder, new IP and injectors, dynamically timed and fuel only turned up one flat (minimum that Banks recommends). I have been driving mixed, about 50/50 Hwy and city. I used to get around 16MPG when it was N/A with winter fuel. I haven't been stomping on it, either; well maybe 2 or 3 times just to get up to speed. It will run like a scalded dog, though.
maybe we need to find a source of good used engine oil, filter it, and run a mix in the fuel. It works well in my Benz.
#30
With turbo and fuel turned up on my truck, I have seen a max of 450F EGT and that is pedal to the floor, hitting the governor up a hill and holding on for dear life. I was not towing anything but I have plenty of leeway before I hit the 1100F max.
Worst case scenario is you need to advance the timing, set the injectors to a slightly higher pop pressure and reduce the fuel delivery. The used oil has longer carbon chains, so it takes slightly more time for them to burn efficiently, thus advanced timing by a few degrees is recommended.
Once I get to the point of burning more than a gallon or so of UMO in my truck, I will write an article about the results.
