trailer battery charging issue - Ford Truck Enthusiasts Forums
Old 05-18-2012, 10:13 AM
Headviking's Avatar
Headviking Headviking is offline
Headviking is gaining momentum as a positive member of FTE.Headviking is gaining momentum as a positive member of FTE.
My brother in law just bought a 39ft 5th wheel. After bringing it home without any problems, found that the 5th wheel batter was dead. Before long we discovered that the trailer (7 pin) was not giving any power when plugged in.
I looked in the truck manual and it has a couple of fuses relays that sound like they should be checked.
-Trailer tow brake controller, Trailer tow battery charge relay coil (10A fuse)
-Trailer battery charge relay (30A fuse)
-Trailer tow battery charge (relay)
Could it be one of these or all. The brake, parking and turn signal lights all work fine. Just the charging of the 5th wheel battery.
His truck is a 2009 F350 PSD with the tow command package.
Thanks
Old 05-18-2012, 11:12 AM
thomabb's Avatar
thomabb thomabb is online now
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
Are you referring to the battery that runs the camper when not connected to shore power? On my camper, that battery is not charged by the truck. But I do have an older unit. Maybe the newer ones are wired differently.
Old 05-18-2012, 09:15 PM
Gearitis Gearitis is online now
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
Oh yea, one of those relays can do it. It has happened on my 5er, also watch for moisture in the plug. Dry that out also just as a precaution.
Old 05-18-2012, 09:21 PM
Fulltimer50's Avatar
Fulltimer50 Fulltimer50 is offline
Fulltimer50 is starting off with a positive reputation.
Be sure the truck is running when you check the voltage at the plug as the relay is off when the truck is.
Old 05-18-2012, 10:50 PM
Headviking's Avatar
Found it. It was the 30A fuse under the hood.
92 F-150 Trailer wiring issues HHCIB 1987 - 1996 F150 & Larger F-Series Trucks 0 10-04-2015 02:48 PM
2009 F250 SD No running lights on trailer Leichardti 1999 to 2016 Super Duty 4 05-26-2015 09:30 PM
trailer brake charging buck_ 1999 to 2016 Super Duty 10 08-21-2014 06:55 PM
Charging towed vehicle battery oldtrojan66 1999 to 2016 Super Duty 10 05-03-2014 01:23 PM
Trailer connector 12v power?? Taurus2415 2007 - 2014 Expedition & Navigator 11 12-04-2013 04:54 PM
Tags
02f250, battery, charge, coil, relay, tow, trailer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
