68 F100 with spare gas tanks - Ford Truck Enthusiasts Forums
Old 05-17-2012, 11:31 PM
Vic68 Vic68 is offline
Vic68 is starting off with a positive reputation.
I just got a 68 f100 Ranger shortbed.Great truck it has ps and factory ac but the thing that wonders me is that the truck has two spare gas tanks under the bed.It still has the one inside the cab and it works.Is these factory or custom made,all the lines are there but not sure if they work.Til now its the only 68 f100 that I've seen with spare gas tanks,and 2 of them.Can anyone tell me if they've seen one or had one like this.Or where I can get info to check if its original or custom.Thanks
Old 05-17-2012, 11:48 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Welcome to FTE.
It's difficult to tell from this angle! Please post some pics of the tanks and pics of the bedside(s) showing the fillers.
Old 05-18-2012, 02:00 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
my 68 has total three tanks
1 in cab stocker
2 left hand quarter panel before wheel ( filler is in fender well )
3 right hand same as #2
right
left
Old 05-18-2012, 02:01 PM
my tanks look fabricated , has stock switch in cab on drivers side floor by seat
Old 05-18-2012, 07:45 PM
rnuner rnuner is offline
rnuner is starting off with a positive reputation.
They are not custom made. Whoever originally bought the truck could have had the dealership add them or he could have added them himself later after he bought the truck. I have a 1968 F-100 with a 390 and I have 3 tanks with the selector switch on the floor next to the driver.
Old 06-07-2012, 10:22 PM
I've been trying to post some pics of my truck but it wont let me,can anyone help.
Old 06-08-2012, 07:09 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Both are aftermarket, not genuine Ford. Ford Dealers usually wouldn't install aftermarket fuel tanks because if something failed, they would have to pay for the replaced parts and the labor to install them out of their own pockets, as the Ford warranty does not apply for aftermarket parts. The quality of aftermarket tanks is another consideration.
More than likely either the dealer sent the truck out to have the tanks installed, or the orignal or a subsequent owner had them installed.
Here on the west coast, the Fey Bumper Co. was the largest installer of aftermarket fuel tanks for dealers and the general public alike.
1967: Ford introduced a 25 gallon auxillary fuel tank as a factory installed option for Styleside pickups. This tank fits on the inside of the left (drivers) side frame rail.
Inside the bed is a shield that protects the filler tube from possible cargo damage.
1967/69: The exposed fuel cap pokes thru the left quarter panel (bedside) above the scallop (bumpside) line, in front of the left rear wheel.
1970/72: The exposed fuel cap pokes thru the left quarter panel below the scallop line, in front of the left rear wheel.
Inside the cab, adjacent to the drivers side of the seat, is a manually operated fuel tank selector valve.
Under the dash, to the left of the steering column is a toggle switch mounted to a bracket. This switch changes the dash fuel gauge from the in-cab tank to the auxillary tank.
The switch bezel is marked: L FUEL TANK R
Is it factory A/C or dealer A/C? Two different types of A/C were offered for 1968/72 F100/350's. Both are "hang-on" units, as their bezels bolt to the bottom of the dash.
1) Factory installed integral A/C is combined with the heater. The A/C controls are located in the same panel as the heater controls.
There are two glove boxes. The A/C expansion valve mounts behind the dash glove box, so its liner is shorter. The other glove box is located in the A/C bezel.
2) Dealer installed economy A/C is not combined with the heater. The two A/C switches are located in the bezel.
Spare Tire/Hitch DDDDDMorgan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 09-25-2016 03:42 PM
Where does spare tire mount on 68 F100? steve340 1967 - 1972 F-100 & Larger F-Series Trucks 42 05-24-2015 11:24 PM
69 f-100 factory 390/c6 truck macattack Vehicles for Sale 0 03-29-2015 09:13 PM
gas tank zombiefied 247 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-24-2015 06:04 PM
In cab(behind the seat) gas tank JohnT 1967 - 1972 F-100 & Larger F-Series Trucks 17 01-08-2006 12:21 AM
Tags
68, bed, capacity, custom, f100, ford, fuel, gas, mainfuel, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
