CD player wont work/memory seat problems.
Hey everyone.
Just when I begin to brag about how trouble-free my 08 Expy EL EB has been the last 14 months, two small problems recently surface.
First, the CD player stopped unloading/loading CD's. I touch the "CD" button and get "NO DISC" when I know darn well there is. When I attempt to eject, or insert a CD I get a "DISK LOAD ERROR" display.
It's the same radio I had in my '06 Five Hundred SEL, that had the exact same problem.
The second concern is the memory seat only adjusts to the "1" setting (the wifes), but when I hit "2" for myself, the seat moves back about an inch, and that's it.
I'm going to take it in this week to get it looked at. Anyone else expierience these issues?
I can't recall how the memory works with two different keys. I want to say each key will retain the memory settings of the 1 position. So you setting it with your key may not work.
If the truck is under warranty get the cd unit swapped out. You can try disconnecting your battery for a couple of minutes, then try to eject your discs. If that doesn't help, you would have to take the unit apart to remove the cd's. If the truck is out of warranty, there are many used OEM radios on ebay for around $100 and they are easy to remove/install.
Texasman, my 2008 has done the exact same thing a few times, loses seat memory and cd player "shuffles" for no apparent reason. Prob is it never does it when the truck's in the shop so dealership doesn't have a fix. Let us know if you find the root problem.
Also, and probably related, my abs sometimes activates for no reason and the traction control has activated in dry (no slip) conditions. I have a suspicion that the electrical module is the culprit.
TSB 08-20-8
10/13/08
STEERING WHEEL ANGLE CIRCUIT AND/OR SIGNAL
FAILURE - C1277-C1278 - BUILT ON/OR BEFORE
4/10/2008
FORD:
2007-2008 Expedition
LINCOLN:
2007-2008 Navigator
This article supersedes TSB 08-10-3 to update the Part List and Service procedure.
ISSUE
Some 2007-2008 Expedition and Navigator vehicles built on or before 4/10/2008 may exhibit a traction control light (TCL) on with diagnostic trouble codes (DTCs) C1277 and/or C1278 (steering wheel angle 1 and 2 circuit failure and/or signal faulted).
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Check to see if the steering wheel rotation (SWR) sensor wiring near the connector has come in contact with or is touching the brake pedal bracket. Vibration of the harness may cause interruption in the SWR signal.
a. If yes, go to Step 2.
b. If no, do not continue with this procedure. Refer to normal diagnosis in the Workshop Manual (WSM), Section 206-09.
2. Repair any chafing that may have occurred.
3. Move the harness towards the driver's side of the vehicle and tuck in front of the 14401 harness above the steering column. Use a tie strap to secure in place.
4. Replace the SWR sensor following WSM, Section 206-09.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
082008A 2007-2008 Expedition, 0.7 Hr.
Navigator: Replace The
Steering Wheel Rotation
Sensor, Includes Time To
Reposition Harness, Check
DTCs, Repair Wires If
Required, And Calibrate
New Sensor. (Do Not Use
With 12650D, 14200A)
DEALER CODING
CONDITION
BASIC PART NO. CODE
14401 12
My stereo did the shufflling thing this morning when I opened my door. Also, both driver seat memory settings were gone.
Some glitch for sure. I would take it in.
78 Ford F150 460
18
06-30-2017 11:58 PM
ojh
06-24-2016 02:56 PM
oneofakind97
11-26-2005 07:32 PM
