Has anyone had to change their shift cable?
Old 05-17-2012, 07:47 PM
wikdwest's Avatar
wikdwest
wikdwest is offline
Went to pick up my daughter at school to take her to doctor to cast her arm, she fell and broke it yesterday, when I tried to put Ex in reverse i had nothing. I was stuck in drive face into a parking spot and no way to move. So I had vehicle towed to my cousins who is an ase mechanic. He told me the cable was on the header and it looked like it had burned through. I probably need a new cable.
So, has anyone had to change their cable and know what is involved to do it? Tools and time involved? Thanks
Old 05-18-2012, 08:25 PM
wikdwest's Avatar
wikdwest
wikdwest is offline
Shifter Cable Installed
Well, I jumped in and changed out my old shift cable for the new one. No big deal, had it done in about 35 minutes without having a clue as to what to do.
If I had to do it again would probably take me about 15 min.
Here is what I did:
1. Unhook cable retainer from shifter under dash--need flat blade screw driver
2. unhook cable from bracket under dash--need flat head screwdriver
3. pry out plastic cable retainer from floorboard--need flathead screwdriver
4. pry out rubber grommet from floorboard--need flathead screwdriver
5. get underneath truck remove cable from bracket--I used flathead screwdriver to push in on one side of squeeze fitting to release from bracket
6. pry cable retainer off transmission ****--I used flathead screwdriver
7. pulled cable out from inside of truck because of rubber grommet
To install:
I did the reverse of above.
I also twist tied the cable to something underneath truck to route away from header to avoid cable laying on header and melting in the future.
I do need to adjust cable at tranny because i have some slop on the PRND21
Have to wait for the wife to get home and run through the gears while I am under truck.
Pricing: I bought cable from Ford, $83 and change out the door after tax. Found it on ebay for about $61 after shipping but my EX is daily driver so I didn't have time to wait for the cable to be shipped.
I also found this that will help anyone in the future:
http://www.frontiernet.net/~jmray/te...BracketR&I.pdf
Old 10-18-2014, 08:50 PM
JaySVX's Avatar
JaySVX
JaySVX is offline
Thank you for this, it will come in handy for me tomorrow.
Old 01-21-2019, 08:02 AM
Bj Minor's Avatar
Bj Minor
Bj Minor is offline
Shifter Cable adjustment
Here is what I did:
To install:
how do you adjust the cable Thanks BJ
aapropane
1999 to 2016 Super Duty
11-13-2017 10:49 AM
BPofMD
Maryland Chapter
09-17-2017 10:19 AM
NeuralMonk
05-07-2008 07:47 AM
Quick Reply: Has anyone had to change their shift cable?
