RUH ROH...this can't be good! Bent rod; cracked arm!! - Page 2 - Ford Truck Enthusiasts Forums
Old 05-17-2012, 09:10 PM
bad12jr's Avatar
bad12jr bad12jr is offline
bad12jr is gaining momentum as a positive member of FTE.bad12jr is gaining momentum as a positive member of FTE.
I've seen this on other forums a few times seems to just be a bad cast and some other perfect conditions that are causes. Lucky the push rod is normally the weak link and will bend before something more expensive.
Just out of curiosity why did you change injectors.
Old 05-17-2012, 09:22 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Quote:
Or not ......
Old 05-17-2012, 10:06 PM
FallstonYJ's Avatar
FallstonYJ FallstonYJ is offline
FallstonYJ is starting off with a positive reputation.
From the time I bought the truck it was hard starting and ran very rough when it first started. Then I had a meltdown towing my jeep when I lost power and started smoking like a locomotive. Spent a couple of weeks researching possible causes and finally had a local diesel specialist take a look. He came away thinking it might just be injector o-rings and recommended I start with that. I ordered the o-rings but then started thinking about how much work that was going to be and did I really want to go through all that and put injectors with 240K on them back in. The conclusion I came to was no. So........after much searching I ordered 150's from Swamps and a TS chip. Hopefully I can get this all back together and will be able to realize the benefits of the new injectors without any more issues with the rods. Sorry to be so long winded!
Old 05-17-2012, 10:08 PM
FallstonYJ's Avatar
Quote:
Originally Posted by Action4478 View Post
Or not ......
Action4478, you suspect it may be something more?? I hope not..........I am way too far into this thing already!
Old 05-18-2012, 05:22 AM
bad12jr's Avatar
They all seem to break in the same spots. Weak points in the cast and just the right amount of heat. There are quite a few competition trucks running up in the 4000 4500 rpm range with no problems. The injector nozzle spring breaking could have been the perfect condition that exagerated the weak point in the rocker.
replacing rocker arm on 6.4 question speakerfritz 6.4L Power Stroke Diesel 3 12-06-2016 08:35 PM
1978 F150 with a 3speed Toploader se˝orEddie 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-14-2016 09:53 AM
How do I diagnose and replace a bent push rod? doug42190 6.0L Power Stroke Diesel 12 06-10-2016 10:25 AM
Bent pushrods Lilbrowntruck Ford Inline Six, 200, 250, 4.9L / 300 14 04-14-2016 10:10 AM
Continuing fuel being pushed through the cylinders - tried everything to correct to no avail TimHaley 1999 - 2003 7.3L Power Stroke Diesel 19 03-16-2015 06:16 AM
Tags
54, 60, 99, bent, cracked, diesel, duty, excursion, ford, injector, jeep, mc, nozzle, problems, rod, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
