6 volt bulbs - Ford Truck Enthusiasts Forums
6 volt bulbs
Old 05-17-2012, 06:52 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
6 volt bulbs
A friend gave me a cool old driving light....I'm thinking about mounting it on my F-1.
My question is, what is the brightest single filament small bulb made? This is a bulb like you would use in a tail light. It currently has a #87 bulb which is fairly bright, just wondering if some other type bulb exists. An LED bulb won't fit in the housing.....
Thanks.
The spark plug is for size comparison...
Old 05-17-2012, 08:23 PM
Smitty49's Avatar
Smitty49 Smitty49 is offline
Smitty49 is gaining momentum as a positive member of FTE.Smitty49 is gaining momentum as a positive member of FTE.
The # 87 has a BA15s base same as a 1156. You might check this site at the reference and tech section and see if there's something you can use differently-
Light Bulbs Classic Auto Bulbs Automotive Replacement Light Bulbs
Interior LED lighting question 06greenstroker 1999 to 2016 Super Duty 26 01-09-2017 03:11 PM
Lighting Larietpsd 2015+ F150 3 04-14-2016 11:47 PM
Replacing gauge light bulbs: BigRed1967 1973 - 1979 F-100 & Larger F-Series Trucks 10 03-18-2016 10:35 AM
mirror directional bulb gsxr1300 6.7L Power Stroke Diesel 8 02-16-2012 10:43 AM
Dome light bulb replacement 1968F250LWB Electrical Systems/Wiring 1 02-02-2003 07:52 PM
Tags
12, 48, conversion, f1, ford, lights, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
