You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
The driver Radius arm is rotten and snapped off when trying to change brackets and bushings. they are no longer stocked in any dealers in the country i am told by 2 different dealers that i called. does anyone here know what is different between the lightning radius arms and a standard f150? i can find those all day at a junk yard but everywhere i call dose not have a lightning. any help is appreciated thanks
__________________
*96 F150 ext cab short box, 2wd 302 mazda 5 speed swap, Hurst Shifter
69 351W heads, Scorpion 1.6 roller rockers, E303 cam
ford racing 4.10 gears with detroit locker
pacesetter LT's 2.5 dual Pypes violator mufflers and 3 inch side pipes
You can use a standard F-150 2wd one just fine. Your tires may rub at full lock. I've heard the Lightning arms are bent in a little more to clear the tires. I can tell you my stock wheel/tire combo rubs on the radius arms at full lock on my '92 F-150, on my '94 Lightning they do not rub.
__________________
'77 F-150 RCLB 2WD 400/C6
408 Aussie Head build in progress
'10 Taurus SEL - Wife's ride
'90 Mustang LX Hatch 5.0 5-speed Daily
Well im not worried about a lil bit of rubbing because there is already rub marks on the stock one even with the stock size tires that are on it now. thank you for responding so quickly also i was just worried about using a standard one as they show different part numbers at the dealers between the two.
__________________
