Brake dust from hell on aluminum rims - any suggestions?
Hey there,
I've got a 2008 Ranger FX4. A while before the warranty expired I took it in to my local dealer to deal with some nagging little problems. While it was in, he suggested a front brake job. Pads are not under warranty of course, but he suggested that he had a cheaper pad in stock, the only complaints he had about them was that they produced "a bit more brake dust".
So, stupidly I had them installed. I noticed (winter driving so I didn't wash my truck for a long time) that the front wheels were much dirtier than the rear ones. Now that spring is here, I've taken to washing my truck more regularly.
The problem is the brake dust has caked on the nice aluminum rims (stock) an I can't get it off with anything. I've tried different wheel & tire cleaners, specialty aluminum wheel cleaners, special abrasive wheel cleaner tools...NOTHING will take the ugly black blotches off the wheels. I wish I never had those pads installed! With the original brakes, the wheels got dirty, but you could get them gleaming clean agin with a bit of elbow grease and some good cleaner.
Hoping someone out there will have some sort of home-brew remedy that I can try. I usually enjoy washing my truck and keeping it clean, but with the wheels in this condition it takes the enjoyment right out of it. I'll try to post a pic a bit later.
Thanks guys,
Thanks guys,
I've used Armor All recipe wheel cleaner with an old tooth brush with good success on the wifes inherited Neon wheels, that were really grimy.
Sprayed it on with the wheel dry, let it soak in good, then went to work with the brush.
Did the same routine with my 94 Taurus aluminum wheels inside/back side, when I had them off for rotation. Guys at the tire shop thought I had new wheels on it!!!!
I cleaned them inside because the grime would bleed out & mess up the outside when I'd wash them. That crud had been in there 10 years or more at the time, so it took a bit of effort to remove it, but they finally came clean. Spray, let it soak (not in the sun so it won't dry) then agitate with the tooth brush on any stubborn spots that don't want to clean up right away, then rinse before the dirty foamy residue dries.
On metal wheels Only, I've also used Fantastic in years past with some success, just don't spray it on plastic wheel covers or trim, as it's a stress crack promoter, so it can cause them to crack if it gets on them & if they're under some mechanical stress from being mounted, or from molded in stress from not being annealed after the molding process, you'll hear them tic as they crack. DON'T let the wife have Fantastic, 409, or any like recipe product to clean her Formica counter tops, as they'll cause them to stress crack & evnentually fall apart!!!!!
Be careful what wheel cleaner you try that might have acid in its recipe, so as not to damage the aluminum wheels surface finish.
Once we get em clean, Michelin has a wheel spray product thats supposed to put a coating on the wheels that'll repel brake dust to keep them cleaner longer & make them tidy up easier when they do finally get dirty, but I've never used it. Saw some yesterday at Ollies clearance house for about $2.50, think I might try it on my vehicles wheels to see if it performs as advertised.
Not looking too good, nothing seems to be working. This is after they've been cleaned:
It's almost like tar but its definitely brake dust washing off the discs & components inside. The little spots will come off, but it takes forever and a lot of work to just get one off. Be warned; if the dealer offers you cheaper pads don't use them!
The absolute best consumer wheel and tire cleaner is Eagle One All Wheel and Tire Cleaner. Make sure the wheels are out of the sun and you let them soak before you scrub them. There are other products that will work better such as Meg's Super Degreaser, but they aren't readily available. Good luck!
