O2 SENSOR REPLACEMENT BANK #2 - Ford Truck Enthusiasts Forums
Old 11-24-2014, 07:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
Old 05-16-2012, 07:42 PM
Osideboy Osideboy is offline
Osideboy is starting off with a positive reputation.
Question O2 SENSOR REPLACEMENT BANK #2
I own a 2003 F-150 4.2 engine 2 wheel drive extended cab. I need some help on finding an easier way to get at the O2 sensor connector on bank #2. I am having a trouble code of P0171 and want to check the sensor to see if it is working.
Old 05-16-2012, 09:24 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Before picking up a wrench, you really need to do some studying...
Old 05-16-2012, 09:47 PM
Thanks for the reply
The reason I want to check the O2 sensor is because the fault code indicates a lean condition in bank #2. I have checked for vacume leaks and did not find any. I also cleaned my MAF sensor and the check engine light is still on.
I am suspecting that it could be a lazy O2 sensor. The problem is getting to the O2 sensor connector which is tucked behind the engine next to the fire wall.
Old 05-16-2012, 10:23 PM
devontrow97f150 devontrow97f150 is offline
devontrow97f150 is starting off with a positive reputation.
Is the truck running rough like it has a miss?
Old 05-16-2012, 10:24 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
You don't understand!
The OX sensor is only reporting the trouble.
It's not the troube it'self.The sensor is the only way the system has to report the problem to you via a code and light.
Look at the code discription.
It says 'LEAN'.
This is not the sensor's fault. It's only detecting the problem.
There is a fault on the intake side your failing to find. Could be an air leak or lack of or even to much fuel causing the OX sensor to detect an oxygen content out of limits.
The sensor trys to correct by shifting the fuel table too far 'lean', setting the code. This is where the 'lean' comes from.
Lean in this case means the computer software fuel table is shifted to it's lean end out of limits. This is what sets the code, not the OX sensor.
If you choose to see it differently, have a good time until you accept it..
The v6 has some areas prone to air leaks.
Good luck
Old 05-17-2012, 08:48 PM
No it has no miss and someone said it might have a leak in the intake or plenum.
When I cleaned the MAF sensor the light went away. I also looked at the O2 wave form and saw that the up stream sensor was not responding at 2500 RPMs. I sprayed starter fluid and heard no difference in RPM change.
Old 05-17-2012, 08:51 PM
OK, I understand there may be some other problem with the lean condition and that a rich condition may be the problem. So where would be a good place to start looking? The lean condition is in the #2 bank which I believe it to be the driver side.
O2 sensor bank one pnp522 Modular V8 (4.6L, 5.4L) 3 07-15-2015 05:40 PM
O2 Sensor Help svtcobra041 1997 - 2003 F150 2 07-15-2010 10:19 AM
What side is bank 2 kev70ss 1997 - 2003 F150 4 06-18-2010 11:46 AM
bank 1 sensor 1 bigcrunch Explorer, Sport Trac, Mountaineer & Aviator 1 10-12-2009 07:30 AM
O2 sensors in Emissions warranty? Fishin76 2004 - 2008 F150 0 10-07-2008 12:30 PM
Tags
2003, 2005, 40, bank, ecoboost, f150, ford, freestyle, light, o2, oxygen, replaced, replacement, sensor, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
