gas mileage
your gears in your differential/s have some thing to say about it too....do you know what ratio you have? do you tow often?
the most economical route is to do good general maintenance, fresh spark plugs, clean that throttle body, filters etc...and watch your driving habits it is not much fun, but that right foot has more to do with it than anything
yes a tuner or chip will help things...if it was me, get one that can take in account things like tire size and gear ratio, towing and improvements like headers & CAI ,etc. Also help keep track of other vital things like trans temp and oil temp.
my list would be, not in any particular order...(others may or may not agree, but it is my list)
electric fans for the radiator
*long tube headers
*high flow cats, (you don't need 4, just 2)
tuner
synthetic oils all the way around
*= most expensive
Tires can make a big difference as well. Some low rolling resistance tires (look at Michelin LTX M/S's or M/S2's for one example) in the stock size will often make a difference. If the truck has huge tires with a deep all terrain tread, these will reduce mileage a bunch (but do be sure you adjust for tire size when calculating mileage if you do have larger tires).
George
George
But not knowing what your driving style or situation is...it's hard to say if there is a problem with your truck.
Presuming that you're trying to drive, ummm, reasonable, and or, not towing 8000 lbs or more everyday..etc. Simple maintenance things you can check /do that can work to improve things.
*change your fuel filter and Air filter
*clean your MAF sensor
*remove your throttle body housing and clean the inside of it with some carb cleaner, there is a couple of EGR ports that tend to get plugged and clean the IAC & throttle plate while it off too.
* check for vacuum leaks , exspecailly the elbow on the rear of throttle body that feed the PCV
*replace the PCV
*check for exhaust leaks
* inflate your tires to proper PSI
*Check tire for odd wear patterns
if the above does not help then & your still driving with the RPMs below 2500. Then you may have to dig deeper
change spark plugs & check compression
check fuel pressure
check for bad bearing on the wheels
check alignment
Here are some areas to look over.
1. Run the tire pressure on the firm side.
2. Coolant temperature should be running in the 195 to 200 degree range.
3. Run in the 55 to 60 speed range and get in the habit of letting off the throttle when not needed. It's a common bad habit.
4. Plugs if they have not been changed.
5. Gas with as little Ethonal as possible.
6. Run some injector cleaner in one tank but expect poor mileage until the next tank if there is any benifit.
7. New Ox sensors may help if the old ones are 'lazy' in responding to gas content.
8. Partial cat restrictions from age or over heating you may not know about but they don't generate an efficiency code yet.
You got it used so you don't really know what it's health is until you get to look close at these items. The last owner let it go for some reason.
Remember it's a truck that weighs between 4600 and 4800 lbs. depending on model, not a light weight smaller car.
Go top the top of this page and click on articles and spec then to specifications, then to your year.
Go down the page to find your model and all the specs for weight, GVR and GCVW for towing etc.
Good luck.
Good luck.
drive 2-3 tanks on it after you get it back from this repair and note the MPGS again, should give you some gains
