Plumes of unburnt diesel at idle
I switched out cold start sol, shut-off sol, injectors and did compression check (one 330 rest 450) but still smoking bad light gray smoke below 900 rpm. Rev to 11-1200 and smoke is passable. Pushing in plunger on IP side causes no change in rough idle.
Should I try advancing (or retarding) pump before replacing? Mileage on pump is unknown - injectors said 2001 rebuild.
any suggestions will receive my best blessing for your time.
Thanks!
Thanks!
Sounds to me like you have a cylinder that is not firing at idle, as indicated per the compression test. Strong IP and fresh injectors might help it, but bottom line is that cylinder is still weak. May be worth it to pull that head to see if it is a burn valve, or at least something simple. While its off you should also be able to tell if its rings, cracked piston.. or whetever it is if its not in the head. Could just be a leaky HG.
plumes of light gray smoke at idle
thanks fellows,
the smoke is there before and after injectors, cold start, new return lines, radiator w/ correct coolent (not losing any) both cold or warm.
the cylinder w'330 lbs is #8 ? (closest to radiator on drivers side).
For a quick look-see, is it possible to buy a single head gasket, and manifold gasket rather than a complete set?
Thanks again!
Thanks again!
thanks fellows,
Thanks again!
Thanks again!
plumes of unburnt diesel at idle
Thanks for everone taking time to help me here. I was just about ordering a replacement IP thinking that may be the problem. I think the suggestion that the low compression on #2 cylinder (how can the right forward cylinder on passenger side be #1 and not count back like other engine cylinder numbering?) anyway, I believe that 330 lbs is not enough compression to burn fuel at idle and will take this motor apart to bring all cylinders up to 450.
youall have a good day dieseling!
Montemontana
Montemontana
Montemontana
Montemontana
The numbering alternates side to side so that the passenger side is all odd numbers and the driver's side is all even numbers. There are numbers on the intake manifold but they may be covered in dirt and grease. Good luck, I hope you get it worked out. If it weren't for the compression test, I would have advised you to look into a bad injector but without good compression, you won't get good ignition. Maybe you will get lucky and it is just a head gasket.
idi1993f350
03-19-2017 09:41 PM
dentsideranger
13
04-18-2012 07:25 PM
