Need ideas for split-rim modification - Page 2 - Ford Truck Enthusiasts Forums
Old 05-17-2012, 10:18 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I have 2 F-600's on the farm with those "bad" wheels on them. As long as the tires are good and they hold air they can stay on there...
I am always on the look out for a deal on better wheels though. Can't justify buying new wheels for a $500 truck....Much cheaper to buy a different truck, IMO.
Old 05-17-2012, 10:39 AM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
Hi .. just wanted to say after spending 900 bucks for a pair of tires installed ..150 each for the tires ..500 for install I was not going to leave my truck hostage at the Firestone dealer here in Victoria Scotia tire ..I am still running W-M on the front .. and Stocton custom rims on the back ..don't wast your money on stocton ..wrong offset ..and no recourse ..I use my truck ..I enjoy driveing it ..and yes it will get rims that will let me drive it without fear if my truck wasn't a unique beast I would rip out the axles and put in something newer that would let me enjoy better brakes and tires try finding 17 inch ..or 17.5 for less then 200 bucks each ..when I can get 19.5 truck tires for 100 each used and serviced anywhere..frustrating ..to say the least ..
Old 05-17-2012, 11:26 AM
K_Man K_Man is offline
K_Man is starting off with a positive reputation.
I'm fairly certain I'll be replacing them and will post here when I'm done if anyone still wants 'em. I use a skidsteer mostly and don't want anything to do with un-neutered WM's loaded, cocked, and aiming into the cab right at me.
I really like the looks of the Dayton spoke design - is it possible to get Dayton hubs which fit the F500 axle? There's a guy on flee-bay that has a set of Dayton wheels ready to go - I just don't know which hub I'd need. Where' the best place to start looking for that type of information?
As for good deals on some of this stuff, you guys might want to look at your local metal scrap yard. I've found unbelievable stuff there, especially since the cash-for-clunkers program. Parts are priced by-the-pound, so the only thing better is "Free." IMO.
Old 05-19-2014, 08:07 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Daytons are a no go. They require a different hub and brake and the cost to change would be prohibitive, even if you only had labor. And then there is the issue of them being a questionable design in the first place. Much heavier and even on a truck unsprung weight is not your friend. And you have a built-in probable wobble as they must be bolted up just right.
Run from Daytons.
Tubless 19.5s with 6 on 8.75 can be had new. Isuzu and Sterling cab overs use them, along with a host of others.
Old 05-19-2014, 08:13 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Good information. The last post before yours is two years old...
Old 05-19-2014, 09:30 PM
Quote:
Lost my mind for a minute. I looked at this and realized I found this looking at posts because of another current thread. Just the most recent in a disturbing trend I'm afraid.....
Old 05-26-2014, 10:17 AM
johnjacob johnjacob is offline
johnjacob is starting off with a positive reputation.
widowmaker replacements
i have some extra 8.25/ 20 6 hole split rims. ( not widow maker )
johnpjacob@hotmail.com
Old 05-26-2014, 10:39 AM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
I tried to find it and can't seem to.Wasn't there a link to a thread about removeing the rivits and actually welding the centers from W-M into a another wheel.I can't remember if it was for 17s or 20s etc.Anyone have the link?
Dave
Old 05-26-2014, 12:34 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
There's been a few references to this over the years and it's a good solution if done correctly. A 17" Budd center mounts perfectly into a 19.5" rim along the drop center. I've had a set where this was professionally done. In theory the same should apply to a 20" disc and 22.5" rim, although I've not had any myself to measure. To me the determining factor on whether or not to do this is the amount of faith a guy has in his welding skill. A wheel failure associated with an accident would be a lawyer's dream come true. Stu
Old 05-26-2014, 01:02 PM
Thanks Stu,I have been trying to figure out something to do with my 17s,I don't think any other hubcap would suit my 56 250.I thought about this maybe as a solution.
Old 05-26-2014, 01:41 PM
Wait a minute. The single wheel 17" is a different animal than a dually 17". The 17" single has a semi-drop center rim where the disc attaches along the widow maker joint. The DRW Budd center disc mounts flush on the flat rim and thus has a wider diameter than the SRW design. There was a member a few years ago that had Stockton Wheel mount his WM centers in new 17" drop center rims. Worked perfectly. Two pics below show the WM center disc riveted to the joint, and second pic is the Stockton custom wheel. Stu
Old 05-26-2014, 02:03 PM
Thanks Stu, exact info I needed.
Dave
Tire/ Brake/ Wheel Options; Your Opinion Matters... 1963 F35 4x4 Napco bc4x4f250 1961 - 1966 F-100 & Larger F-Series Trucks 11 08-21-2016 10:27 PM
When were 16.5" wheels available? BarnieTrk 1961 - 1966 F-100 & Larger F-Series Trucks 36 07-13-2014 01:58 PM
Split-rim wheels vs Budd wheels Neil_E. Large Truck 23 05-22-2011 12:42 PM
1963 Ford F350 fravon 1961 - 1966 F-100 & Larger F-Series Trucks 4 12-28-2005 03:41 PM
17" split-rim replacement KeyLimeExpress 1961 - 1966 F-100 & Larger F-Series Trucks 0 02-23-2004 05:35 PM
Tags
1951, 20, f500, ford, international, modification, replace, rim, rims, split, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
