2012 4x4 E-Locker 4.30 Re-gear - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-16-2012, 07:59 AM
F350Centurion's Avatar
F350Centurion F350Centurion is offline
F350Centurion is starting off with a positive reputation.
Hello folks, great site.
Does anyone know what the diff is for a 2012 F350 6.2 4x4 4.30 E-Locker axle code 4M? Can't see any tags on it and the numbers of the housing don't jive with anything I can find. Looks like a Sterling 10.5 12 bolt pattern.
I want to gear it up to 4.89 or 5.13 and looking for the right parts, but one place told me that it is some new axle that is a 37 spline and we won't see rings/pinions for it for over a year?
Thanks!
Old 05-16-2012, 09:25 AM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
the new single tire F350 truck's have the same 10.5 axle but it has bigger 37 spline axle shafts. I haven't heard anything about gears being different because its still the same center section just different axle shafts. Any 10.5 gear set will work you just have to keep that awesome factory locker!
Old 05-16-2012, 09:27 AM
i assume you have the e-locker so why do you need the axle code for? all the gear shop needs is thats its a 10.5 Sterling rear axle out of a F350 that has 37spline axleafts. everything else center section is still the normal 10.5
Old 05-16-2012, 09:32 AM
randys ring and pinion are the only ones that have gears for the 2011 -up F350, only problem is they are stock Ford gears so nothing lower than 4.30....
Diff Wizard
Old 05-16-2012, 10:36 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
What size tires are you wanting to run?
Old 05-16-2012, 11:03 AM
Quote:
I've got 36" Toyo M/Ts on there.
Crap, so no gears past 4.30 at the moment, sux. Thanks for the answers.
Old 05-16-2012, 11:31 AM
4.30s should be fine given the lower 1st gear ratio in the new transmission. 1st gear is now about 20% lower than in the 5R110.
Old 05-16-2012, 11:47 AM
Yea, true - it's no slouch now by any means
I have some other mods on there that pep it up. I need to setup my sig I guess to list the details...
2012 F250 Factory E-Locker Moundainner 1999 to 2016 Super Duty 9 08-14-2016 09:27 AM
2012 Elocker into a 2005? rustybottoms88 1999 to 2016 Super Duty 5 12-31-2015 11:29 AM
New Truck Fireboater 6.2L V8 10 03-31-2015 08:24 PM
Axle swap 3.73 to 4.30 in a 2011 F250 6.2 Jettix2 1999 to 2016 Super Duty 23 09-30-2013 08:02 PM
Request for e-locker wiring schematic QwkTrip 2009 - 2014 F150 3 06-13-2012 06:52 PM
Tags
105, 2012, 430, 4x4, 67, axle, electronic, elocker, f250, f350, ford, gears, locker, lockers, rear, regear, sterling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
