Trying to figure out which speedometer gear I need with bigger tires - Ford Truck Enthusiasts Forums
Old 05-16-2012, 08:20 AM
GotFord83 GotFord83 is offline
GotFord83 is starting off with a positive reputation.
Been searching the forums and can't seem to figure this out correctly....my stock setup is 195/75/15 with a 3.55 gear ratio with a 19 tooth gear. Trying to figure out which speedometer gear will correct my speedometer with 275/45/20's on the truck? Any help would be much appreciated
Old 05-16-2012, 12:16 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
What is the OD of the tires? I could figure it myself, just don't have the time.
What transmission do you have?
With these 2 items, I can assist in finding the right tooth count gear and part number to get the speedo close. The speedo unit itself has a fine adjustment that may need tweaked to finish the correction.
You mention 3.55 gears, so I'm guessing it's an 83-86 with an 8.8 rear axle.
Old 05-16-2012, 12:17 PM
lavatan's Avatar
lavatan lavatan is offline
lavatan is gaining momentum as a positive member of FTE.lavatan is gaining momentum as a positive member of FTE.
Didn't I answer this question in another post here?
Quote:
There are gear calculators out there that will get you into the ballpark for your setup.
Here is one I've used before:
Speedometer Gear Calculator
I pretty much spoon fed you the answer there....
Old 05-16-2012, 12:34 PM
OD of the tires in 30.4 and the transmission is AOD yes it's a 83 with a 8.8
Old 05-16-2012, 12:36 PM
lavatan's Avatar
Wow. Really? Is it that you don't want to work to get the answer your looking for and want RW to do all of it for you or that you are just intentionally ignoring me to be a jerk.
Old 05-16-2012, 12:44 PM
Quote:
Wow, sorry that wasn't the case at all....I'm reading this from my phone and when I pulled it up I didn't see your post....thank you for posting the link I will take a look at it
Old 05-16-2012, 12:52 PM
lavatan's Avatar
Sorry. It just seemed like you ignored both posts where I put the link and you wanted the information given to you. I have a problem with someone not willing to put in the research or work when the answer is given to them. Now, if you had questions about how to fill out the calculator I would understand that.
Old 05-16-2012, 12:53 PM
Quote:
Those are a bit taller than the typical 235/75-15 (28.5-29) offered on 2wd trucks, but very close to the typical 31x10.50-15 (30-31.5") that was available on 4wd.
With this info, perhaps one of our members who has access to the Master parts catalog (or your local ford dealer) could look up what the factory calls for with this combo. If you have a 2wd, you may still have to try adding or subtracting a tooth from the factory spec gear for the 235/75-15, since I don't think a 31" tire was offered for a 2wd AOD/3.55 combo, if so, it would have likely been in an F250 and I don't know what the equivilent 16"/16.5" tire would be.
If it's 4wd, then whatever gear the chart shows for a 31x10.50-15 should be well within the adjustment range of the speedo head.
Old 05-16-2012, 12:55 PM
I looked at that calculator, and it asked for info that I don't know on my own trucks. Yes, there are a few things I don't know about my trucks, so I find it very reasonable that this could be the case for most others as well.
Old 05-16-2012, 12:57 PM
lavatan's Avatar
What information is it looking for that you don't know?
Old 05-16-2012, 01:03 PM
Drive gear teeth, and speedo RPM. I know these are pretty standard numbers, since the C6 uses a cast gear that is a permenant part of the the output shaft, I just don't know how many teeth it has, and I dern sure ain't tearing it apart to count........
Especially since I knew there was a chart in the MPC that listed speedo gears by application (trans/tire size/axle ratio). Of course, it's dependant upon a factory standard spec.
Old 05-16-2012, 01:09 PM
lavatan's Avatar
I figured the OP had counted the teeth when he had the truck tore apart. He had the transmission and engine out. That would be real easy to count the teeth then.
From the old post:
Quote:
Hey guys in the middle of swapping the old 5.0 motor for a rebuilt one and putting in a new transmission, now the motor and teams are already out of the truck at this point.....I went from the stock 15's to 20's with a 275/45/20....with having the motor and trans out is there a way to correct my speedometer or do I need to wait until the truck is back up and running?
As for the RPM's. I think the most common is 1000 RPMs at 60mph. You should be able to ask a transmission shop for confirmation on that or get a method to test it.
Old 05-16-2012, 01:12 PM
It's a two wheel drive....I'm in the process of swapping the motor and trans.....not to mention the older cars is all new ground for me.....so needless to say I'm doing a lot of searching on here and learning a lot....sometimes using the net on the phone isn't the best way...when I try to get the calculator to submit it doesn't do anything for me I think it's not responding on my phone
Old 05-16-2012, 01:15 PM
I don't know if I said it wrong or maybe I got a little lost in this, but if we are talking about the speedometer gear going into the trans it is a 19 tooth, it's in the first post, I should have separated it better
Old 05-16-2012, 01:16 PM
lavatan's Avatar
OK. Assuming that you have a 7 tooth drive gear and the speedo needs 1000RPMs to get to 60mph the number of teeth on the driven gear is 16.5. I would probably go to a 16. That way you'll be running a bit fast but you won't get a speeding ticket.
Speedometer help Scrpmny 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-23-2015 06:19 PM
For The Speedometer Guru's... rogue40 1961 - 1966 F-100 & Larger F-Series Trucks 15 12-27-2013 08:43 PM
Which Speedometer Drive Gear? BiltFordTuff 1973 - 1979 F-100 & Larger F-Series Trucks 11 07-23-2011 05:53 AM
I Need Gear/Speedometer Help peterbilttrucker 1973 - 1979 F-100 & Larger F-Series Trucks 27 05-03-2009 03:01 PM
Speedometer Drive Gear schaad25 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-16-2007 12:03 AM
Tags
93, chart, davidson, drive, f150, ford, gear, granny, harley, larger, pickup, ranger, speedo, speedometer, tires, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
