Ok I see what you guys mean now, I have the transmission in my garage still so I can take a look in....sorry for all the trouble and headaches guys. Like I said this is a lot of new stuff at once but I'm learning a lot on here and bringing a 83 back to life
No problem. I'm having my own speedo issues. I can't even get the drive gear off my transmission to replace it. I just drive by tach for now. 2500rpm = ~55mph
Since you have the transmission out you probably won't have to take the tailshaft out. Just look in the hole and count the teeth.
Hey atleast you have the tach, mine doesn't.... Will be adding one at some point once I get back to the interior stuff....i will take a look at it when I get over to the garage and see what I can find out
I had to add an aftermarket. The factory tach that I took out of another truck doesn't work quite right. Let us know what you find when you look at the gear on the transmission.
From poking around the web it seems many modern speedo's run 1000 RPM and display 60 MPH. For electronic speedometers this seems to be the common case. Other values are said to be stamped on the back of the Speedometer itself.
If there is anything stamped on the back of the speedo unit, it will require disassembling the cluster to read it. Just looked at the spare cluster I have, and only the shaft where the cable attaches is visible, without removing it from the housing.
So was finally able to get to the garage last night and check out the transmission.....it was hard to see through the little hole but between my brother in law and me we think there is 8 teeth on it, does that seem like a likely number for the AOD trans?
I have no clue, as I never messed with an AOD trans. It sounds plausible though.
I think the standard is 1000 RPMs at 60mph. That's what I figured using that calculator and my speedo is finally working correctly. So, if you use that calculator figuring in your transmission gears, tire size and differential you'll get to where you need to be.
