Trying to figure out which speedometer gear I need with bigger tires - Page 2 - Ford Truck Enthusiasts Forums
Old 05-16-2012, 01:21 PM
GotFord83 GotFord83 is offline
GotFord83 is starting off with a positive reputation.
Ok I see what you guys mean now, I have the transmission in my garage still so I can take a look in....sorry for all the trouble and headaches guys. Like I said this is a lot of new stuff at once but I'm learning a lot on here and bringing a 83 back to life
Old 05-16-2012, 01:29 PM
lavatan's Avatar
lavatan lavatan is offline
lavatan is gaining momentum as a positive member of FTE.lavatan is gaining momentum as a positive member of FTE.
No problem. I'm having my own speedo issues. I can't even get the drive gear off my transmission to replace it. I just drive by tach for now. 2500rpm = ~55mph
Since you have the transmission out you probably won't have to take the tailshaft out. Just look in the hole and count the teeth.
Old 05-16-2012, 01:38 PM
Hey atleast you have the tach, mine doesn't.... Will be adding one at some point once I get back to the interior stuff....i will take a look at it when I get over to the garage and see what I can find out
Old 05-16-2012, 01:49 PM
lavatan's Avatar
I had to add an aftermarket. The factory tach that I took out of another truck doesn't work quite right. Let us know what you find when you look at the gear on the transmission.
Old 05-16-2012, 02:28 PM
lavatan's Avatar
I found this on that calculator site:
Quote:
From poking around the web it seems many modern speedo's run 1000 RPM and display 60 MPH. For electronic speedometers this seems to be the common case. Other values are said to be stamped on the back of the Speedometer itself.
Old 05-16-2012, 02:32 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
If there is anything stamped on the back of the speedo unit, it will require disassembling the cluster to read it. Just looked at the spare cluster I have, and only the shaft where the cable attaches is visible, without removing it from the housing.
Old 05-16-2012, 02:34 PM
lavatan's Avatar
I have one at home as well (actually 3). I'll tear it apart and take a look. Not that hard to disassemble.
Old 05-16-2012, 03:28 PM
Interesting let us know what you find
Old 05-17-2012, 12:36 PM
lavatan's Avatar
Looks like Photobucket is having an issue today. Here's what it says on the back of the speedometer:
EITF-17265
2177/8-1
2292/93
I don't know if this helps at all. There were no other numbers or anything clear that says how many revolutions at 60mph.
Old 05-20-2012, 09:10 AM
So was finally able to get to the garage last night and check out the transmission.....it was hard to see through the little hole but between my brother in law and me we think there is 8 teeth on it, does that seem like a likely number for the AOD trans?
Old 05-21-2012, 02:46 PM
Bump to top
Old 05-21-2012, 04:14 PM
Quote:
I have no clue, as I never messed with an AOD trans. It sounds plausible though.
  #28
Old 07-03-2013, 08:23 PM
1981Ranger's Avatar
1981Ranger 1981Ranger is offline
1981Ranger is starting off with a positive reputation.
I know i had to put in a white 17 teeth gear but i have 33's
  #29
Old 07-04-2013, 12:12 AM
lavatan's Avatar
I think the standard is 1000 RPMs at 60mph. That's what I figured using that calculator and my speedo is finally working correctly. So, if you use that calculator figuring in your transmission gears, tire size and differential you'll get to where you need to be.
Truck not shifting correctly, speedometer not working Southern Buckers 1994.5 - 1997 7.3L Power Stroke Diesel 68 10-02-2016 12:13 PM
Speedometer Gear Randle 1967 - 1972 F-100 & Larger F-Series Trucks 10 09-18-2015 09:23 PM
Speedometer help Scrpmny 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-23-2015 06:19 PM
For The Speedometer Guru's... rogue40 1961 - 1966 F-100 & Larger F-Series Trucks 15 12-27-2013 08:43 PM
Which Speedometer Drive Gear? BiltFordTuff 1973 - 1979 F-100 & Larger F-Series Trucks 11 07-23-2011 05:53 AM
Tags
93, chart, davidson, drive, f150, ford, gear, granny, harley, larger, pickup, ranger, speedo, speedometer, tires, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
