Another Front Turn signal Problem Thread - Ford Truck Enthusiasts Forums
Old 05-15-2012, 08:48 PM
rivet96's Avatar
rivet96 rivet96 is offline
rivet96 is starting off with a positive reputation.
Unhappy Another Front Turn signal Problem Thread
Hey All, So im putting my truck back together and I dont have turn signals. We had the front clip off all winter, signals were working then. I have also RE/RE'd the steering collumn with another used one (parts truck that was on the road recently, signals working on it) I checked my fuses and checked my grounds, everythings seems to be ok. I noticed when I was checking my sockets; i could see that the element in the bulb was barely JUST barely lit but not flashing, tried several flashers (swapped with hazards which work A-OK) and nothing changed. When I put my test light on it, the test light stayed light on, and when I wiggled it it would signal briefly then stop.
I am truly stumped on what to do
Turn signal switch problems?!? 52' fordnut 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-21-2015 10:07 PM
Electrical problem fp_5 2004 - 2008 F150 1 03-02-2015 04:42 PM
turn signal problems boo-yaa138 1967 - 1972 F-100 & Larger F-Series Trucks 16 03-10-2014 12:48 PM
Aftermarket turn signal problem. Please help! jhaas63 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 01-03-2014 06:20 PM
I am going crazy! Turn signal lights.. Eagle460 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-18-2012 02:39 AM
Tags
turn signal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
