4.2 oil pan gasket - Ford Truck Enthusiasts Forums
4.2 oil pan gasket
Old 05-15-2012, 08:27 PM
crazy96863's Avatar
crazy96863 crazy96863 is offline
crazy96863 is gaining momentum as a positive member of FTE.
4.2 oil pan gasket
I need to replace the oilpan gasket on my 4.2 and I can find is that silicone stuff. Do they make a rubber, cork or silicone hard gasket of some sort for this engine? I know the silicone stuff will work but the quality of work maybe a little bit more subjective than a hard gasket.
If it matters the engine is in a 2005 Freestar. Thanks a bunch!
Old 07-06-2012, 06:43 PM
ArcticF250's Avatar
ArcticF250 ArcticF250 is offline
ArcticF250 is starting off with a positive reputation.
I am rebuilding mine in a 98 f150 and the kit did not come with an oil pan gasket. All it had originally was silicone.
Old 07-06-2012, 06:49 PM
crazy96863's Avatar
Thats sort of the conclusion I came to... Actually worked pretty well.
Old 07-06-2012, 06:51 PM
crazy96863's Avatar
The silicone that came with the kit was barely enough; i used an extra tube I had laying around.
Silicone Gasket Material - cheap 1972-34ton 1967 - 1972 F-100 & Larger F-Series Trucks 12 03-25-2017 05:16 AM
Gaskets seal Johno.h 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 07-20-2015 09:04 PM
Best way to install thermostat?? tsuess 1973 - 1979 F-100 & Larger F-Series Trucks 12 11-02-2014 11:14 AM
Oil pan gasket Burlcojoe 1957 - 1960 F100 & Larger F-Series Trucks 4 07-02-2014 08:11 PM
Carb rebuild tips and suggestions - Motorcraft 2150 silver777 Fuel Injection, Carburetion & Fuel System 2 03-14-2011 10:23 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1997, 2003, 42, 42l, change, changing, e150, f150, ford, gasket, oil, pan, replace, v6, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
